Another 2017 with P11EE code
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Olddawg, Aug 13, 2022.
  1. Aug 19, 2022 at 1:21 PM
    #61
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Yes, Toyota called for all those parts, I'm sure it was to find the cause.
    Olddawg[OP] likes this.
  2. Aug 19, 2022 at 1:45 PM
    #62
    Olddawg
    Olddawg [OP] Well-Known Member
    2017 Taco v6
    That's what I hoped to learn through out all of this. Toyota saw, examined, found and adjusted. I also hoped to learn if this was something we could/can avoid. I again thank you for chiming in!
    My truck is still in surgery. I figure a few days to process the protocol the tech needs to go through. I figure about mid next week I'll get a call and I'll be starting over with breaking in a new engine.
    Ngneer likes this.
  3. Aug 19, 2022 at 4:12 PM
    #63
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Math is hard.
  4. Aug 20, 2022 at 3:31 PM
    #64
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Given it's near end of life for the 3.5, I'm not seeing Toyota fixing the issue without a class action forcing their hand.
  5. Aug 20, 2022 at 3:34 PM
    #65
    Benny22
    20Tacoma
    These sort of post make me wish i"d bought the 2.7.:(
    Ngneer likes this.
  6. Aug 22, 2022 at 6:23 AM
    #66
    Olddawg
    2017 Taco v6
    You may have missed my update.. They know the issue and are repairing. You don't see this post 2020 (inclusive). It's the valves on #1, #3 or #5 as I been told and learned (so far).
    Another has posted that he's driven to 135K after repair around 40K was done. I just read another here that has done very close to the same with no further issues. Toyota has a handle on it!
    Not worry unless you are far out of the warranty range, yet then is not when it seems to occur.
    Ngneer and FloridaFree like this.
  7. Aug 22, 2022 at 6:33 AM
    #67
    rolled93slc
    Jerry
    Lynchburg VA
    Exactly, All the ones I have done were right at the end of the 5/60 warranty period, but still in warranty. I have seen several with over 180K that have not had any issues. It seems like they fail under warranty or not at all.
    Ngneer likes this.
  8. Aug 22, 2022 at 6:40 AM
    #68
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Has happened on a 2020 model also. #2 and #6 cylinder exhaust valves.
    Ngneer likes this.
  9. Aug 22, 2022 at 6:42 AM
    #69
    rolled93slc
    Jerry
    Lynchburg VA
    Haven't ran into that, YET. Hopefully it is a small number of engines effected.
  10. Aug 22, 2022 at 11:44 AM
    #70
    Olddawg
    2017 Taco v6
    Curious about the engine build year.. I read of two, but both were 2019 engine builds. Serial numbers... This actually first I've heard of #6... You have someone I can contact on that? I'm curious..
    Ngneer likes this.
  11. Aug 22, 2022 at 11:46 AM
    #71
    Olddawg
    2017 Taco v6
    I'm not confirmed on the firing order or cylinder placement (drivers/passenger). I'm assuming 1,3,5 are a bank & 2,4,6 is the other. If true, have you seen/heard of an issue on the 2,4,6 side?
    Ngneer likes this.
  12. Aug 22, 2022 at 11:56 AM
    #72
    rolled93slc
    Jerry
    Lynchburg VA
    You are correct about cylinder numbering. I have ONLY seen it on 1,3,5. But there could have been some with 2,4,6. On the older 4.0, the heads came from different builders. That's why one head had NGK plugs and the other Denso plugs. It could be the same with the 3.5 heads. But they all have the same plug in them.
  13. Aug 22, 2022 at 11:59 AM
    #73
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    He's talking about his truck...
    SR-71A likes this.
  14. Aug 22, 2022 at 12:05 PM
    #74
    nhsmith
    nhsmith Why can't I leave well enough alone?
    Rick
    Merrimack, NH
    2018 Tacoma SR5 Silver Sky Metallic
    M.O.R.E Off-Road front skid plate, Bestop Softopper Bed Cap, BedRug XLT Bed Mat, Rough country Soft Tri-Fold Tonneau Cover, RedRock Baja Replacement Grille with LED Lighting and DRL, AJT Design TSS Relocation Bracket, Barricade HD Stubby Front Bumper, Rough Country Black Series 20” Dual Row LED Light with Amber DRL, Cali Raised Wiring Harness for Dual Function Light Bar, Overland Equipped Complete Auxiliary Power Kit, CH4X4 Push Switch for Toyota Tacoma 3rd Gen - Grille Led Lights Symbol 2 - Blue LED, Brite Box Anytime Fog Light Control Kit, Universal Firewall Boot, Uniden BEARCAT 980 40- Channel SSB CB Radio, FireStik FL3-B Three Foot FireFly Antenna w/Tuneable Tip, CBI 3rd Gen Tacoma Antenna Mount, N2 Designs Tacoma Plug & Play Remote Start Kit, Toyota Tacoma Gentex Homelink V4 Mirror, Taco Garage Dashtop Multi Mount (DMM), Offroam Vent Phone Mount Kit, Cali Raised LED 9-Piece Interior LED Kit, Rough Country Driver & Passenger Side Molle Rack System, Hi-Lift Jack HL485 48”, EAG Jack Bed Mount Bracket for HiLift Jack, BUNKER INDUST Off-Road Traction Boards with Jack Lift Base, Hi-Lift Jack LM-100 Lift-Mate, Rhino USA D Ring Shackle, Rhino USA Shackle Hitch Receiver, Rhino USA Recovery Tow Strap, RHINO USA Folding Survival Shovel w/Pick, LZCG1301 Cargo Gate Truck Bed Divider, Kidde FA110 Fire Extinguisher, MFC Universal Aluminum Adjustable Fire Extinguisher Mount, EAG Bed Rail Flag Pole Mount Holder. Lift kit and tires planned.
    Add another to the P11EC list. 2018 SR5, 58k miles. Built in Baja California. Service advisor knew right away what it was when I told her what code I pulled. Two others ahead of me in the shop for the same thing. She estimated about a month turn-around to replace the head. Lack of qualified tech's to do the job was the issue. New head was ordered Saturday. Covered under warranty. Judging by her reaction and what she told me it's something Toyota is seeing a lot more of in the 2018 +/- model years. Whether I keep this truck or trade it, I'm not sure. I just added a some mods and I still have the balance of 100k extended warranty if any other issues pop up.
    Ngneer likes this.
  15. Aug 22, 2022 at 12:15 PM
    #75
    Olddawg
    2017 Taco v6
    Hey there! I'm up in Auburn, NH! Mine is also a Baja build, yet until my truck comes back can't chase the factory of engine build. Not even sure how relevant it is any more, yet we should know. Thank you.
    Where did you bring yours in? I brought mine into Manchester, NH (IRA). Service 'Advisor' had no clue.. Tech told me his first, yet the seniors third (mine). All the parts were boxed right there in front of my truck. The tech told me he has a set procedure for the issue. That made me feel much better that Toyota knows and has procedure set to remedy.
    Ya... I was also debating if I would keep or move on. Looking like keep! Be interesting as this continues how I can work an extended warranty due to this experience. I know others have picked up another year.
    I've read it's a 24hr job to replace.. a month seems long! Very curious who has/had your truck!!!
    Ngneer likes this.
  16. Aug 22, 2022 at 12:18 PM
    #76
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    haha I was going to say.. he ought to know what cylinders went down, its his truck after all.
    skeletron[QUOTED] likes this.
  17. Aug 22, 2022 at 12:19 PM
    #77
    Olddawg
    2017 Taco v6
    You seem to be the guy to ask! What's the book say the Head/Valve replacement should take?
  18. Aug 22, 2022 at 1:43 PM
    #78
    nhsmith
    Rick
    Merrimack, NH
    Mine's also at Ira. Dropped it off last week. Service advisor (Jenny) knew right away what the code meant. Mine was 3rd in line for repair with only 2 techs qualified to do the job. Having a set procedure for the issue tells me that Toyota is well aware of the problem. I may have inadvertently opened the door for a month when I said to her I had read that time frame on forums. She initially said she couldn't give me a time estimate but called me a day later with the month estimate. Not a huge problem but I need a 4wd for an upcoming trip to OBX. She hasn't returned my call requesting a rental. I'm leaning toward keeping it only because of the extended warranty.
    Ngneer likes this.
  19. Aug 22, 2022 at 2:44 PM
    #79
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Threads like these keep popping up and not making me feel warm and fuzzy at 47k miles.
    Ngneer and TRD-ED like this.
  20. Aug 22, 2022 at 4:23 PM
    #80
    nhsmith
    Rick
    Merrimack, NH
    Same. I bought this truck because of the Toyo reliability and I had one many years ago. I thrashed that '86 SR5. It was bulletproof - until I hit a tree, HA!
    Ngneer likes this.
