Another 255/85/16 thread.
Discussion in 'Wheels & Tires' started by GARYRED, Sep 5, 2011.
  1. Sep 5, 2011 at 10:05 AM
    GARYRED
    GARYRED [OP] Well-Known Member
    David
    Huntsville Al.
    2010 REG CAB 4X4
    885's with OME shocks in front and back. 1.5AAL. BFG KM2 255/85/16
    Finally have the tire money saved and l'm looking at buying some 255/85/16. I only wheel about once a month, but i love the way they look. I'm not planning on re-gearing anytime soon, so will these tires tear up my tranny or engine if i don't re-gear? By the way, I will be using my stock steelies and my truck is a reg cab 4cyl with a 5 speed.
  2. Sep 5, 2011 at 10:13 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you read the big thread on this tire size ?
    May be some info in there that helps
    http://www.tacomaworld.com/forum/wheels-tires/155849-255-85-r16-owners-experience.html#post3143870
  3. Sep 5, 2011 at 10:18 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    you will be fine and if you wanna run a bigger tire this is the best way to go.....i love mine...they have a smaller contact patch when at street pressure and weigh less then 285's...much less rolling resistence also...they are also taller then 285's for better ground clearence.....if you had an auto you would have to worry about gearing but with a 4x4 4cyl 5spd...i believe you have 4.10 gears and will turn them just fine with a minimal loss in power...btw tall skinnys are awsome on the trail
  4. Sep 5, 2011 at 10:19 AM
    GARYRED
    David
    Huntsville Al.
    2010 REG CAB 4X4
    I've read several different threads on the 255/85/16, and most of them talked about the truck just being sluggish starting out or little trim work will be needed. I really didn't see anything about it tearing up the motor or tranny. So just trying confirm, before making this purchase.
  5. Sep 5, 2011 at 12:18 PM
    hard2kill
    Rhinebeck NY
    i have a 2.5in lift and had to trim a tiny bit off inner fenders....the auto guys are alil sluggish but standard guys dont have a too noticible difference.....id say i lost 5% acceleration...my truck is a 4.0 v6 but i only have 3.73 gears....your 4cyl has 4.10 gears which make up for the smaller motor....if your gonna go bigger then a 265-75-16 then the 255 are deff the way to go imo....285's will drag you down much more then the 255's and like i said you get better clearence with the 255's and better milage and less road noise
  6. Sep 5, 2011 at 12:20 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    regear after you buy the tires. The motor and tranny will be fine if you don't, but trust me you will love having the power back and the engine and trans will thank you in the long run. They will be under a lot less load after regearing.
  7. Sep 5, 2011 at 2:59 PM
    GARYRED
    David
    Huntsville Al.
    2010 REG CAB 4X4
    Thanks for the input. Just wanted to make sure I wouldn't tear up anything, being that this is also my DD. I will re-gear at a later time but I want to get a bumper and winch after my tires.
  8. Sep 5, 2011 at 6:32 PM
    hard2kill
    Rhinebeck NY
    lets see that build thread start :) 2nd gen reg cabs are badass offroad and cool looking modded
