Another 30k maintenance question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr Ribby, Jan 21, 2015.
  1. Jan 22, 2015 at 11:09 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    1. Synthetic is usually better, but as long as you stay on top of the maintenance, regular is fine.
    2. Depends on what the fluid is. Oil - 5,000, Differential - 30,000, Transmission - 60,000. Check your manual.
    3. Other than standing over him, you can't. So find a mechanic or dealer you trust.
    4. Every 30,000. Denso or NGK is stock. I prefer Denso. How to link for referrence.
  2. Jan 22, 2015 at 11:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    DO THE REAR DIFF AT THE VERY LEAST..... honestly it should be changed out after the first 5k cus it gets NASTY... i did mine at 6k and switched to synthetic in the rear diff at that point.
    plugs, n rear diff at the very least.
  3. Jan 22, 2015 at 1:38 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    the 90k for plugs is for the fancy iridium plugs. the standard copper plugs should be changed at 30k.
