Another 4" spindle lift question
Discussion in 'Suspension' started by Greywolf, Feb 5, 2013.
  1. Feb 5, 2013 at 1:52 PM
    Greywolf
    Greywolf [OP] Well-Known Member
    mike
    Virginia Beach, Virginia
    2011 Prerunner MGM Grey
    undercover tonneau color matched, wet okole seatcovers, n-fab step bars, AMP research bedstep, Maxtrac Spindles with toytec 3" ULK. 285-70-16 toyos and Fuel Throttle wheels
    I found this lift on HeadStrong off-road. I plan on staying with the stock rims and tires 265-65-17 will i need to use spacers?
    Thanks.
  2. Feb 7, 2013 at 6:42 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Yep, you can maybe do 1" bora or def spiders 1.25". Its the back spacing of your wheels, it will just put the inside lip of your rim/tire to close to spindle arm causing you to rub.
    Sweet package!
  3. Feb 7, 2013 at 6:52 AM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    I like this package! Thanks for posting this, DEFINITELY on my list now...
    and yeah what he said about the spacers.
  4. Feb 7, 2013 at 9:48 AM
    Greywolf
    mike
    Thanks for the info. Now how bad will it look with 265-65-17's
  5. Feb 7, 2013 at 9:53 AM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    I just installed the spiders 1.25 on my truck and it looks decent. You can a used set on here for quite a bit off retail. Good to have for piece of mind.
  6. Feb 7, 2013 at 10:20 AM
    Mr Salty
    Hermmy
    Lots of chrome
    Well it won't look great, bigger tire would, but it won't look bad either. Seen a couple trucks with the 265s and spindles and not bad at all.
    Little more tire is always a plus though, just leave the bilies set to zero and all should be fine. I hear those spindles lift you 3.75".
    Search around on here and check some photos out w/spindles and 265s, they are on here ;)
  7. Feb 7, 2013 at 10:59 AM
    Greywolf
    mike
    Can't afford the big tires and rims yet, thats why I will run stock tires and rims. Thanks for the info though
  8. Feb 10, 2013 at 8:44 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink 5100 Blinstein set at 2.25 1" procomp rear block with TSB leaf pack. 5100 Blinstein on back 17x9 kMC wheels 0 BS 265/70 17 Nitto Terra Grapplers
    Hi Op, did you ended up installing this kit? If so:
    How does the ride compares with the original ride?
    Any cons?
    Pictures?
    Thanks
  9. Feb 11, 2013 at 9:35 AM
    Mr Salty
    Hermmy
    Lots of chrome
    Spindles keep the ride stock unless you adjust the Bilstiens which reload the coils. The OME packs may be a bit stiffer in the rear in the beginning, but once you break them in they should ride better.
    I would love to photos of someone with the kit though.
  10. Feb 11, 2013 at 4:18 PM
    Greywolf
    mike
    Have not bought the lift yet still alittle short on funds then i have to find someone to install it.I also wondering if you would need UCA's too.
  11. Feb 12, 2013 at 9:51 AM
    Mr Salty
    Hermmy
    Lots of chrome
    Nope, only if you plan to max the Bilies out. Still yet you could get away without new UCAs, you would just be pushing it with the alignment at the 2.5 setting.
    That’s the beauty of the spindles, you get the lift you need (3.75”-4.0”), can use the bilies as intended and replace stock shocks, keep your stock coils which ride nice and leave you UCAs alone and get spot on alignment when all said and done. You can also go a bit higher in the front if you want and spend nothing more thanks to the adj bilies. It’s a really complete kit that’s for sure.
  12. Feb 12, 2013 at 9:55 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    you dont need a uca....and i dont think you need spacers if you run stock tires.
