Another 4x4 engagement question
Discussion in 'Technical Chat' started by MSgtDunn, Dec 7, 2022.
  1. Dec 7, 2022 at 9:49 PM
    MSgtDunn
    MSgtDunn [OP] Member
    Don
    2008 Tacoma ext cab 4x4
    ute tray
    Everyone, I apologize if this seems like a broken record thread. I've had my Taco for a little over a year now. When I bought it, I had a shop in Vegas and the 4x4 knob worked, seemed a little slow. I have forgotten to regularly engage the 4x4 knob and now all I get it the blinking green 4 wheel and the blinking 4 low. I took off the transfer-case solenoid and "on the bench" the motor works and turn the gear. On the Taco I cannot hear anything.
    1. Can the transfer-case solenoid run if the front differential solenoid is not functioning?
    2. If the dial is bad, are they rebuildable or just buy another one?
    Thanks gentlemen
  2. Dec 7, 2022 at 10:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
  3. Dec 8, 2022 at 7:55 PM
    MSgtDunn
    Don
    ute tray
    Appreciate all the input and the write ups!!
    1- Contacts were like new
    2- Seem to have clocked it appropriately (3 O'clock position?)
    3- Will check the 4wd ecu with the wonderful information provided!!
    Thank you
    Dm93 likes this.
  4. Dec 8, 2022 at 8:07 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No problem, post your results so I can maybe help further.
  5. Dec 8, 2022 at 8:34 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No! The ADD first needs to “activate” before the 4WD ECU will allow the tcase to send power to the front diff. It sounds like your problem may be the ADD motor that hangs off the front diff. It’s prone to corrosion on the contacts but can be cleaned/soldered pretty easily.
    edit: I had that backwards; see below
  6. Dec 8, 2022 at 8:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Actually the 4wd ECU shifts the Transfer Case first and then the ADD when both engaging and disengaging 4wd, it only shifts the ADD once the transfer case has completed it's shift.
    A problem in either one can cause a flashing 4wd light but typically the only time the 4lo light will flash is when there's a problem in the transfer case limit/detection switch circuits.
    6 gearT444E likes this.
  7. Dec 8, 2022 at 8:47 PM
    TireFire
    Olympic Peninsula
    Ah dang, you’re right! Brain fart! Guess it would have to so that the spider gears stop spinning in opposite directions lol. Not sure what tf I was thinking there for a minute…
    But he’s saying 4hi isn’t engaging either, so I still think ADD actuator
    Dm93[QUOTED] likes this.
  8. Dec 8, 2022 at 8:55 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Could be but the system locks itself out when one or more of the limit switches are out of range from where it expects them so any error in the system will cause a lockout and flashing light(s).
    That's why when the light(s) are flashing I would like to know the voltages on the limit switches so we kinda have an idea of where to start without even crawling under the truck. For example if they were all at 12v we would want to check the voltage on the ground at connector PA Pin 18.
  9. Dec 8, 2022 at 10:06 PM
    MSgtDunn
    Don
    ute tray
    Outstanding information Gentlemen. Thank you
    Dm93 likes this.
