Another 5100 Eibach Question
Discussion in 'Suspension' started by goufcustom, Apr 30, 2012.
  1. Apr 30, 2012 at 7:50 PM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    WHen assembling 5100s with Eibachs (or any other coil) is positioning the coil so that it adheres to this setup critical... :notsure:
    I got mine together, this weekend, and I was careful to make sure the top plate was positioned correctly, and the bushings and everything where in the right order but totally forgot to position the coil, "correctly", and just put them in there. There was a lot on my mind, considering the compressed coil at my feet ready to explode... :rolleyes:
    (this photo shows my passenger side, where the right side is to the front, see the sway bar.)
    So before I go get it aligned, I was wondering if it really mattered when doing aftermarket coils and 5100s. I haven't seen any mention of it on the forums.
  2. May 1, 2012 at 5:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not overly critical in my opinion. If you end up having the UCA hit the coil, then I'd move it. Mine aren't lined up they way they ought to be either and I haven't had any issues at all. For a taller lift or an extended travel application it would probably make a difference.
