Another 5100/eibach thread
Discussion in 'Suspension' started by mrlooney88, Jul 17, 2011.
  1. Jul 17, 2011 at 5:45 PM
    mrlooney88
    mrlooney88 [OP] Well-Known Member
    Ohio
    '10 d/c sr5 4x4
    I have a 2010 dc and I am going to install 5100's and eibachs set on "0" up front. I am also installing 5100's and a 2" aal to the rear. Does anyone think I will have any vibes or any issues at all? Also would like opinion on wether I should have done 1.5 aal instead of 2 or will that make any difference.
  2. Jul 17, 2011 at 5:57 PM
    bcb97
    bcb97 Well-Known Member
    x2! :popcorn:
  3. Jul 17, 2011 at 7:37 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Feel free to chime in.
  4. Jul 17, 2011 at 7:43 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    You're going to increase your factory rake since you're lifting the front 1.6 inches and the back 2inches, and you may have vibes so you may want to get an OME CB drop if you get vibes. I personally would have done the 1.5" AAL but to each his own!
  5. Jul 17, 2011 at 9:08 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Thanks for the input. I think I will try to call them in the morning and have them switch to 1.5" aal before they ship it.
  6. Jul 17, 2011 at 9:35 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    I just installed 5100s w/ eibachs, set at 0, 1/4 spacer and a 2" toytec AAL. I have a Access cab and, from what I read, I expected and got over the 1.6 that the eibachs are supposed to give you. I got roughly 2 5/8" from the eibachs. I was worried about the 2" AAL being too much, but I wanted the truck to sit higher in the rear. As it sits now, it's has a slightly greater rake than stock but it's only been a week and a half and about 300 miles so they're probably going to settle a bit more. I believe the double cab weighs more than the Access cab, so if you want to maintain the factory rake, I'd stick with the 2" AAL!
  7. Jul 17, 2011 at 9:50 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Thanks for the input WTtoolman. Have you had any issues with vibes yet?
  8. Jul 17, 2011 at 10:08 PM
    WTtoolman
    William
    Omaha, NE
    Luckily, I haven't had any vibrations at all. However, I just pruchased the Toytec/OME Carrier bearing drop bracket from another member. No vibes, but it reduces the angle of the driveshafts. Even if only by a few degrees, it's worth it, in my opinion.
  9. Jul 17, 2011 at 10:24 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    I've read about that cb drop bracket with mixed reviews. So I don't know what to do. 1.5" or 2" aal. So confusing. I would like to think that since I do have a double cab that I won't get as much lift up front cause there is more weight and the 1.5 would be ok and I would not need the cb drop.
  10. Jul 17, 2011 at 10:35 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Go with the 1.5 AAL
  11. Jul 17, 2011 at 10:45 PM
    WTtoolman
    William
    Omaha, NE
    Do you have the TSB rear springs? If yes, I think the 1.5 would be the way to go. Also, Do you want your Tacoma to sit more level or maintain the higher back end?
  12. Jul 18, 2011 at 2:05 AM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    I want to maintain the higher back end but don't want it to go any higher then it already is. I also don't want to use the cb drop either.
  13. Jul 18, 2011 at 6:57 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    agreed
  14. Jul 18, 2011 at 7:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Same exact set-up. I went with the 1.5" 3-leaf progressive AAL and kept the factory overload in. I'd go with the 1.5" AAL.
    I also purchased the OME CB drop kit but it looks like it'd make any vibes worse. It'll help the angle from the CB to the rear diff but make for worse angles from the CB to the transfer case. I did not install the CB drop kit for this reason. I had vibes initially and they have since gone away.
  15. Jul 18, 2011 at 5:17 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Thanks to all for the input. I have decided on the 1.5" aal. Will post picks of before and after in a couple weeks when I get it all together.
