Another 5100 question
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgen7, Aug 16, 2010.
  1. Aug 16, 2010 at 8:54 PM
    1stgen7
    1stgen7 [OP] Member
    Salt Lake City
    03 TRD SR5 4x4 XtraCab
    I searched, but could not find what I was looking for. I just got my bilstein 5100s from downsouth today (thanks guys, really fast shipping and great customer service)! I need about an inch of lift in the front to keep my tires from rubbing so I figure the middle setting is what I need. What I can't seem to understand is how changing the spring resting location by ~.5" can lift the truck 1.25". I am sure it is something really stupid I am missing, but can someone smarter than me please enlighten me as to the physics of the whole thing?
    Thanks in advance!
  2. Aug 16, 2010 at 9:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well the simple answer is the raising of the coil spring seat which of course raises the spring, the more technical answer (& I'm just taking a swing at it here) is you increase the "Pre load " to the coil & that change in energy dynamic forces the coil upward (in direction the spring is wound I assume:confused: ) Somebody else probably has a better answer :D
  3. Aug 16, 2010 at 10:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Without demonstrating it mathmatically (not that I could do that in any case) because of how far inboard the strut is in relation to the upper and lower ball joints, you get approximatly double the distance in lift for however much lift you put at the strut.
    For example, a 2.5" lift spacer doesn't actually measure 2.5" high, more like 1.25", yet when installed above the strut you end up 2.5" higher.
  4. Aug 16, 2010 at 11:39 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Nice. I can get my head around that. I was curious about this too.
  5. Aug 17, 2010 at 2:45 PM
    iDigTulsa
    iDigTulsa Well-Known Member
    Luke
    Tulsa, OK
    03 DoubleCab TRD SR5 4x4
    Free Alarm Mod, Grey Wire Mod, Reverse Leaf Spring Helper Mod, Kenwood Deck, Memphis 10'', Yakima Roof Rack, Debadged Sides,Silver Toyota Skid Plate, Injen CIA, 3.5'' Amsoil Dry Filter, 17 x 7.5 Tundra Split Spoke Alloy's
    x2. Repp added for making something so complex sound so simple!
  6. Aug 17, 2010 at 6:39 PM
    1stgen7
    1stgen7 [OP] Member
    Salt Lake City
    Now that makes sense. Why didn't I think of that? Thanks for the replies.
