another 5100 question
Discussion in 'Suspension' started by jr114, Dec 14, 2009.
  1. Dec 14, 2009 at 8:25 PM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    are these shocks adjustable while they are on the truck or do they have to be taken off and placed into a spring compressor?? just curious.
  2. Dec 14, 2009 at 8:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    You can adjust them while they are on the truck but when you set them up initially you put them where you would like them, then you fine tune them after they are installed.
  3. Dec 14, 2009 at 8:29 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    how do you tune them after install? doesnt the c-clip adjustment give it whatever lift you want and in order to adjust that you have to take them off?
  4. Dec 14, 2009 at 8:34 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    You have to take it off and compress the spring in order to move the clip
  5. Dec 14, 2009 at 8:35 PM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    I think he's talking about a set of billys w/ the stock spring, not aftermarket coilovers that u adjust w/ a spanner wrench
  6. Dec 14, 2009 at 8:39 PM
    jr114
    Jon
    SoCal
    Truck
    ya sorry. to clarify im talking about the stock coils.
  7. Dec 14, 2009 at 8:40 PM
    08pretaco
    Oliver
    az
    thats what confused me, thanks for clarifying. i took a quick pic of my 5100's real quick if i had to post but ya with the collars its adjustable with them being on the truck, if your using springs that dont allow for that then you have to remove and compress to lift
  8. Dec 14, 2009 at 8:41 PM
    08pretaco
    Oliver
    az
  9. Dec 14, 2009 at 8:44 PM
    jr114
    Jon
    SoCal
    Truck
    ya thats what i figured. I dont really need them to be super adjustable. Im trying to get info cause i need.. want.. to re-lift my truck. one idea is to use the camburg 4" spindles with the bilsteins with stock springs set at 0.85". give me the same look as the rcd 4.5" lift but with out the drop bracket and cheaper. just need some info on what to level the rear with. will 2" aal and the 5100 shocks out back work?
    before anyone asks yes i have a prerunner no 4x4
  10. Dec 14, 2009 at 8:47 PM
    08pretaco
    Oliver
    az
    haha no no way im doing the camburg spindles and 5100's up front with the eibach 1.6" springs and im looking into something close to 3" to level then ill have to go with the 5125's longer length shocks
    that refreshing that someones done some hw before asking!
  11. Dec 14, 2009 at 8:51 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Sorry about that I was thinking adjustable coil over.
  12. Dec 14, 2009 at 8:51 PM
    jr114
    Jon
    SoCal
    Truck
    ya well you guys are definitely the guys to talk to about this stuff. i really appreciate all the input. this is most likely the setup im gonna go with. just out of curiousity..how do you plan on getting 3" in the rear? havent been able to find anything yet. post some pics when you get it done. hopefully have all the parts end of the month/begininng of the year
  13. Dec 14, 2009 at 8:53 PM
    08pretaco
    Oliver
    az
    allpro has a 3" leaf setup and ome has a 2.75" (i think it is) leaf pack, im leaning towards the ome pack moreso then i gotta get a hold of downsouth and talk to them about which 5125 length i should get
    i think the next az mod day is jan 3rd which is when ill be putting this stuff on, with the help of fellow tw members :thumbsup:
  14. Dec 14, 2009 at 8:59 PM
    jr114
    Jon
    SoCal
    Truck
    08pretaco...what wheel and tires are you planning on going with?
  15. Dec 14, 2009 at 9:05 PM
    08pretaco
    Oliver
    az
    i got moto metal 951's 16x8 4.5bs with 265/75/16 mud terrain.
    im waiting till i burn through those and probably gonna go with a 255/85/16 or 295/75/16 then changing the gears to 4.56 and adding a locker at that time. that wont be for another 4-5 months probably
  16. Dec 14, 2009 at 9:10 PM
    jr114
    Jon
    SoCal
    Truck
    nice right now i have the same wheels 951 17x9 with 285/70/17 terra grappler a/ts.
  17. Dec 14, 2009 at 9:12 PM
    08pretaco
    Oliver
    az
    i kinda wish i went with the wider tire but glad i didnt otherwise id be more willing to go wider with the tires but with only having a 4 banger and adding those wide tires im gonna go nowhere quick which is why i like the 255/85/16 alternative. got any pics of your truck? post em
  18. Dec 18, 2009 at 3:50 PM
    jr114
    Jon
    SoCal
    Truck
    why would you have to regear while running a 295/75/16?
  19. Dec 27, 2009 at 4:35 PM
    jr114
    Jon
    SoCal
    Truck
    08pretaco are you still planning on using the eibach 1.6" coils? Not sure if im gonna use those or if ill get a stock coil. Im planning on just doing the front for right now until i get the parts for the rear and I dont want it sitting at roughly 5.5" with a 1.5" aal in the rear. think thats too bro'd out even for me.
  20. Dec 27, 2009 at 4:58 PM
    08pretaco
    Oliver
    az
    ^ yup they go on tomorrow :D
