Another Alignment Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tweeek, Apr 30, 2012.
  1. Apr 30, 2012 at 3:37 PM
    tweeek
    tweeek [OP] Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    I recently installed Toytec's OME kit on my 06 AC. 885's no spacer. Got roughly 2.5-2.75"
    I brought it to the shop for an alignment, they told me "Its in spec" like I assumed they would. I held out of UCAs to see how close we could get aligned. Numbers came out as following:
    Caster
    Left 1.3
    Right 1.4
    Camber
    Left 0.6
    Right 0.8
    Toe
    Left 1/32
    Right 0
    I think ideally it should be Camber 0 & Caster 2.0+
    I didn't specify any settings, because I didn't read any other posts until I left :( He didn't tell me whether it was maxed out or anything, but said it fell into Toyota's specs. I also noticed in the printout he had my tires as 245/75/16s while I run 265/75/16s though I don't know if that makes a difference.
    Question is, is it worth taking back to get the numbers tweaked? It does seem "Touchy" at highway speeds, but drives straight. I don't expect to get my numbers perfect without UCAs, but can they do better?
    Is my camber low enough I don't have to worry about tires wearing premature?
  2. Apr 30, 2012 at 3:45 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    "Edit to caster" is not a tire wearing angle, but yes, it is low, and will cause the stability issues you are experiencing.
  3. Apr 30, 2012 at 3:50 PM
    tweeek
    Victoria, BC
    "If the camber is out of adjustment, it will cause tire wear on one side of the tire's tread"
    from http://www.familycar.com/alignment.htm
    If I am not mistaken (Which I could be) its caster causing the "touchy" feeling.
  4. Apr 30, 2012 at 3:53 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Fixed that for you.
  5. Apr 30, 2012 at 3:54 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That's a pretty decent alignment for 3" lift with no UCAs. I'd drive it for a while and see how I liked it.
  6. Apr 30, 2012 at 5:40 PM
    tweeek
    Victoria, BC
    Good to know. So to clarify, at this point, it is my comfort level with the highway driving and not a concern of wearing tires correct?
  7. Apr 30, 2012 at 7:13 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    You did, thank you. Thats what you call a brain fart!:facepalm:
  8. Apr 30, 2012 at 7:18 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Yes, it won't handle as well as it would with more uh, uh, caster, yeah, thats it, but it won't cause tire wear. This without the brain farting this time.:) Sorry about that.
  9. Apr 30, 2012 at 10:11 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep.
  10. Apr 30, 2012 at 10:32 PM
    seric007
    seric007 Well-Known Member
    they gave up a little camber for caster....
    its your call, live with the stability or get new UCA's and call it a day. I drove mine for a month, it made me insane and i pulled the trigger on the UCA. haven't looked back once.
    HIGHLY recommend the SPC UCA's - look around they can be had for 380.
  11. May 1, 2012 at 9:19 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    My tires wore quite badly with camber at .7. I'm about to buy UCA's.
