Another Alignment Thread; question about caster
Discussion in '1st Gen. Tacomas (1995-2004)' started by steve o 77, Jun 4, 2010.
  1. Jun 4, 2010 at 11:19 AM
    steve o 77
    steve o 77 [OP] braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    So I went and got my alignment done at Firestone a few days ago and Im kind of concerned about the numbers. I only lifted about 2 inches so I shouldn't need UCA's, but these caster numbers seem really bad to me. From what I understand, caster does not affect tire wear but rather steering stability at high speed and steering returning to center after a turn. My truck seems to drive great all the way up to 70 mph and the steering returns nicely.:confused: So whats going on? Should I go back and tell them to get these numbers in spec?
  2. Jun 4, 2010 at 2:23 PM
    steve o 77
    Steven
    In a corn field, OH
  3. Jun 4, 2010 at 3:12 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    The caster angle is too steep. This may cause a vehicle that does not like to hold a track going down the road, is more sensitive to cross winds and feels like it darts. The steering response will feel quick at low speeds compared to one with a higher caster angle. 1.75 should be the reading you see there.
  4. Jun 4, 2010 at 3:25 PM
    steve o 77
    Steven
    In a corn field, OH
    Thank you. I think I'll take it back to Firestone tomorrow (I got the lifetime alignment) and let them know how I want it.
  5. Jun 4, 2010 at 4:39 PM
    ShadowFalken
    Jim
    Maryland
    10 Off Road
    When you take it back, give the tech credit for getting the the toe and camber centered as well as the sheet shows. Some techs will do a Visine alignment (just get the red out). This one at least got the tire wearing angles in the ideal area not just inside the gap to turn it green.
    Let us know how it works out. By the before readings it looks like you got a "toe and go" adjustment. The camber was not changed
  6. Jun 4, 2010 at 4:42 PM
    steve o 77
    Steven
    In a corn field, OH
    will do. Im going tomorrow morning.
  7. Jun 7, 2010 at 10:48 AM
    steve o 77
    Steven
    In a corn field, OH
    I went back to firestone yesterday and he didn't want to mess with it. He said that if it drives good then don't worry about it. I agree with him since the toe and camber are set so good, I don't have to worry about irregular wear. I haven't taken it on the freeway yet but driving around town, it drives great.
  8. Jun 7, 2010 at 11:27 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It seems on 1st gens to get that higher caster number (2.0 to 2.4) we do need to have an aftermarket UCA. Otherwise the adjuster is maxed out.
    I didn't see this thread the other day when you first posted but tonight I will look at my sheet from Firestone. Right now I can't be certain but I think my numbers were much the same as what you got. And the tech told me much the same as you were told.
  9. Jun 7, 2010 at 4:48 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    What should each number read at?
    I am lifting my Tacoma in a week and it will need to be aligned. I'd like to just give the tech the numbers so I know it is right.
    Thanks
  10. Jun 7, 2010 at 6:32 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Camber can be sacrificed to get caster up. You can get camber in spec and caster better. Ask the alignment tech to get the caster numbers up. Caster being low makes it wander. it is not a big deal until you get caster up around 1.5 and notice how much better it drives. I told him that the camber could be sacrificed a little to get the caster higher. My goal was to get Caster around 1.5
    I ended up with these numbers
    Camber -0.2 0.0
    Caster 1.2 1.6
    Toe 0.07 0.05
    No where near > 2.0 on the caster but I can live with these numbers.
    It was very interesting working with the tech and seeing that caster and camber are inter related. Toe is no problem. The machine was new and cost $35,000 with the lifts. That was the forth alignment after I lifted the truck. 1) to align after I lifted first time. 2) to align after I lifted it to a full 3 in. 3) Lowered it 3/4 in to keep CV angles more reasonable. 4) to get the caster higher.
    I drove the truck today > 80 miles and the caster helped. Not a big change in driveability but noticeable. Caster being off is really no big deal. I can't see why 600 for a UCA would be needed for just caster.
  11. Jun 7, 2010 at 6:47 PM
    steve o 77
    Steven
    In a corn field, OH
    Wow, thanks for the replies. I took the truck on the freeway today and it does seem to wander a bit if I let go of the wheel. I also have some driveline vibes to fix. I guess I need to go back again to get that caster a bit better. Good thing I got the lifetime alignment!
  12. Jun 7, 2010 at 9:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You may find that the caster cannot be made to go any higher on your truck. At least not without compromising toe.
    I was looking at my report from Firestone. The tech was able to get the toe and camber right on 0.00 for both on both sides. However, the best he could do with caster was 1.03 on the left and 1.10 on the right. Both these numbers are outside the spec (1.28-2.78). Because the adjuster is maxed out, he said the only way to get the caster higher, would compromise the toe.
    Bottom line for me (at least so far) is the truck drives acceptably. If tire wear is good, as it should be with these toe and camber numbers, I'll be happy. I can't justify (yet) laying out $600-$700 bucks for aftermarket UCAs. I reserve the right to change my mind on that. :eek:
  13. Jun 7, 2010 at 10:39 PM
    steve o 77
    Steven
    In a corn field, OH
    Cool, I think I'll head over tomorrow and tell the tech that it is wandering a bit on the freeway. Ill see what he says and report back. I really don't want to get UCA's either and can deal with wandering if I need to.
  14. Jun 8, 2010 at 11:09 PM
    steve o 77
    Steven
    In a corn field, OH
    okay, I went to firestone today and left with these numbers. He says the caster adjustment is maxed out.
    I want to know how the toe got so messed up in just a few days. I did do some light offroading.
  15. Jun 8, 2010 at 11:15 PM
    scocar
    scocar hypotenoper
    I dunno. They didn't tighten it enough after the last alignment?
    Hey, I just noticed the top of the readout says "except off road." To me, that means not off road. Are they using the right spec? Did you check the spec ranges on the printout against the FSM?
  16. Jun 8, 2010 at 11:18 PM
    steve o 77
    Steven
    In a corn field, OH
    I did not but these numbers seem good besides the caster, which I can live with. It just likes to wander a bit on the freeway.
  17. Jun 8, 2010 at 11:25 PM
    scocar
    scocar hypotenoper
    Man, it's gonna bug me if mine wanders, because that is what the crappy struts and have partially been causing. But you have bigger tires (I'm at stock), so that may have some affect and the handling. I hope I don't end up wishing I got the 880s instead. I am still two weekends away from being able to do it...going nuts.
  18. Jun 8, 2010 at 11:29 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    If you want to check it yourself get under the truck and look at where the lower control arm bolts to the frame of the truck. The two big bolts holding each arm on have camber lobes which appear as giant washers with little degree marks on them. You'll notice each of the bolts is off center in the washer. When you rotate the washer/camber lobe, it pushes or pulls that leg in or out. That is how the adjustment is made. If any of the four camber lobes/washers, appear to be to the extreme left or extreme right side of the vehicle than you are maxed out and no more adjustment can be made.
  19. Jun 9, 2010 at 6:17 AM
    steve o 77
    Steven
    In a corn field, OH
    Just putting the tires on (before the suspension) did make it wander a bit more. And the wandering really isn't bad since it took me about 5 minutes to even realize it was doing it.
    Thanks, Ill check it out.
  20. Jun 9, 2010 at 6:25 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Just for the record, the toe didn't really change from the first to the second visit. When you left the first time, it was .13 total toe (which is the most important toe reading, in regards to tire wear and handling), and the 2nd time initial reading was .14.
    The difference side to side just means the steering wheel was slightly off center (cosmetic).
