Another alignment thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mike686, Jun 9, 2010.
  1. Jun 9, 2010 at 12:28 PM
    mike686
    mike686 [OP] Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    sorry guys for this but i have searched and searched but havent found many answers, i have put on the Toytec 3'' lift and about to put on the lr uca's i have a 2010 trd or if that makes any difference but i want to know if anyones done this to their 2010 and what numbers for both alignment and the ucas were, need help dont know much about what the numbers mean
  2. Jun 9, 2010 at 12:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    0* Camber
    0* Toe
    2.4*-3.1* Caster
    are pretty much ideal for the 2nd Gen Taco. I'll let someone who knows it better explain what they mean.
  3. Jun 9, 2010 at 12:43 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
  4. Jun 9, 2010 at 12:47 PM
    mike686
    Michael
    Waldorf
    See Build Thread
    thanks for such quick responses now guys
  5. Jun 9, 2010 at 12:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    lol, I just made a thread like this about a week ago. Its such a pain sifting through the hundreds of search results for alignment.
    But yeah, 0 toe, 0 camber, and about 2.5 caster.
  6. Jun 9, 2010 at 1:09 PM
    SCFirefighter
    Stephan
    Cary, NC
    I didn't know you could actually tell someone to set the alignment to something specific. I always thought the computer system would calculate what the best alignment is for your specific vehicle characteristics. Learned something today :)
  7. Jun 9, 2010 at 1:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    The computer tries to go to these numbers but the technician has to be competent/patient enough to get it set just right. A lot of times they just get it "close enough" and call it good.
  8. Jun 9, 2010 at 1:12 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    good luck getting caster that good with stock UCA's. i think mine is around 1.2
  9. Jun 9, 2010 at 1:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    And most larger/chain type places will tell you "We can't take specific requests." They get it into the spec'd range and call it done.
  10. Jun 9, 2010 at 2:25 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If you adjust your alignment on the front end you should have the VSC recalibrated by the dealer.
  11. Jun 9, 2010 at 3:47 PM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
    -0* Camber
    -0* Toe
    -Stock tires "ideal" would be 2.1*Positive Caster
    -33" tires "ideal" would be 2.4* Positive Caster
    -35" tires "ideal" would be 3.0* Positive Caster
    As far as the UCAs, are you asking what to preset the caster at?
    LR uca is actually 2* positive caster over stock when you set the plate at 0* and 4* positive when set at 2*.
    It seems most will set the plate at zero and get it to align.
    http://www.tacomaworld.com/forum/suspension/57162-lr-uca-install-initial-setting.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/40470-ucas-alignment.html
  12. Jun 9, 2010 at 4:39 PM
    mike686
    Michael
    Waldorf
    See Build Thread
    so its already set at 2* positive, im going probably 33's so set the plate at 4* positive?
  13. Jun 9, 2010 at 5:01 PM
    splitbolt
    Arkansas
    I would try them at +2* first.
    Setting them at +4* should get you there too; TC UCAs are +4* and people are hitting the numbers.
  14. Jun 9, 2010 at 5:03 PM
    mike686
    Michael
    Waldorf
    See Build Thread
    so i set the ucas to these numbers, and then take it to toyota and they can align it correctly?
  15. Jun 9, 2010 at 5:23 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    my lr. i set all the way foward..+++
    helps with the body cab mount rubbing as well
  16. Jun 9, 2010 at 5:26 PM
    splitbolt
    Arkansas
    Maybe.
    If there is enough adjustment left in the factory alignment cams(located on the lower control arms) to get your desired caster; around +2.4*.
    If not they will have to take it back apart and move the plate for additional caster. I don't know if the dealership would be willing to do this or not.
  17. Jun 9, 2010 at 6:08 PM
    mike686
    Michael
    Waldorf
    See Build Thread
    i got a pretty cool dealership i fucked with one of the alignment screws by accident on the BHLM and they fixed it for free and i told them that i screwed it up too haha it was pretty cool
  18. Jun 9, 2010 at 6:20 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
  19. Jun 10, 2010 at 7:15 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Thought the same thing, but after attempting to get my truck aligned at 2 independant shops, who ended up being too busy to get to it, I took it to Firestone and asked if they'd align it to my specs. They said sure, but since it's not in their listed spec window that they wouldn't guarantee it. I told them that my specs were in the window, just on the edges, but the guarantee didn't matter to me, set 'em as I ask.
    My original settings were actually all green, and they normally would not go any further (a camber of .8 was in spec, luv it...). Re-iterated I wanted it set to my specs, and they did just that.
    They set it right where I requested 0/0/2.1 (stock tires, .85 Billy lift, TSB springs) and it drives great. Much less "floaty". Still a bit figity, but much better then original or after the alignment that the dealer did after my TSB spring install.
    Only complaint was that they disconnected my battery and cleared my radio, odo, etc. Ticked me off as I have never had the battery disconnected for an alignment. Makes no sense to me why that was done, but I didn't go back to question them on it.
  20. Jun 10, 2010 at 7:38 AM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    here is my thread on all my problems. i have a 2010 i put a 3" spacer lift on mine and LR UCA's after five alignments they got it right (i had to show them how to adjust the UCA'S)
    anyway, set the new uca's at 0 (which is actually +2) and set them all the way out. from there anyone with half a brain should be able to get you to what you want (which is 0 0 2.4+)
    what all the numbers mean
    toe is easy if the tires are pointing towards the middle of the truck that is toe and that is bad zero degree's of toe means the tires are facing straight forward.
    camber is the amount the tire leans in or out. camber has a lot to do with tire wear so proper camber is a must. camber is used for turning we are not in race cars so 0 (meaning the tire sets perfectly flat on the road and does not lean) is great if you corner fast a little .1 negative would be ok.
    caster has to do with how the truck tracks down the road and also effects things like bump steer. it has nothing to do with tire wear.
    you want your steering to lead the tire not be even or behind.
    cars like bmw have a lot of caster because they are build for high speed so they need it (the faster you drive the better it will handle with higher caster) also the idea of the side being different has to do with the crown of the road. so if you set the left side at 2.4 and the right side at 2.7 on a flat road it will pull to the left (it will always pull to the side with the least caster) but for a lot most roads in America there is some crown so to compensate they alignment guys set them a little different. most of our roads slope to the right so with less caster on the right side the truck will counter act the crown of the road.
    i will say i have had mine all acrossed the board but thanks to a couple member here i have mine at 0 0 and 2.4 on one side and 2.7 on the other and the truck drive like a dream!
    i hope this helps
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/93946-wtf-can-anyone-get-my-alignment-right.html
