Another auto transmission thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Retired Heat, Jun 22, 2016.
  1. Jun 22, 2016 at 11:14 AM
    Retired Heat
    Retired Heat [OP] Member
    2016 SR5 DCSB 4x4
    Bilsteins, 265/75/16s, Billet Grille
    So here's my problem. I am trying to check my trans fluid level. As soon as I put the transmission in temp check mode, the D light is already blinking. I live in AZ and the outside temp is over 100. Could it be possible that as soon as I start my engine and start cycling the trans fluid it is already over the temp required to check it?
  2. Jun 22, 2016 at 11:26 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    They recommend 95 degrees or less.
    113 degrees is too high.
  3. Jun 22, 2016 at 11:35 AM
    nyskier
    nyskier New Member
    2016 sr5
    When I checked mine here in ny on a 75 degree day it was already blinking after backing it down the driveway, idling, opening up garage and putting 4 ramps under the wheels. Waited an hour, even then the solid D came on quickly after idling a few minutes. I believe you could be overtemp pretty quickly
  4. Jun 22, 2016 at 11:51 AM
    glider_guider
    glider_guider Well-Known Member
    2016 Red Tacoma TRD OR 4x4
    Yep. I expect you're already over temp if your truck is sitting on blacktop asphalt and the air temp is 100 or more. :eek:
    Kilokato likes this.
  5. Jun 22, 2016 at 12:51 PM
    Retired Heat
    2016 SR5 DCSB 4x4
    Ok so if the trans has too much fluid in it will I get a light or a code? Here is what I did due to the temp issue. I put 200 ml of fluid in it... about 10 oz. No reason other than I was using a syringe and 100 ml measuring cup. I pinned the thermostat, started the truck and put it in temp check mode. Of course the D was flashing from the get go.
    I pulled the "check level" plug and allowed fluid to drain until it was not dripping but a very slight steady run. Kinda like the last little bit of oil from the drain plug during an oil change. Then I plugged everything back up. I got about 70 ml back out. So all in all I put in about 130 ml or about 4.5 oz.
    I don't think it is really enough to make a difference but I will test drive and see here in a bit. My only symptoms were slow shift from R to D and what feels like a hesitation on acceleration from a stop. It seems like when I give it gas from a dead stop (sign or light) it would rev just a slight bit, then grab and accelerate abruptly.
    And a little tip for those who want to check their fluid level. I removed the 3 nuts holding the cat / exhaust heat shield and moved it out of the way. It is super sharp and cramps the work area. 2 mins off and back on saved me some cuts.
  6. Jun 22, 2016 at 12:56 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    The hesitation between R and D is just how it is I guess. Mine has been checked twice, I know that my fluid is good, yet it still hesitates. No other irregularities though.
    poppy510 and PROseur like this.
  7. Jun 22, 2016 at 12:58 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    None of this would be required if Toyota would just step up acknowledge the problem and have Quality Assurance doing their jobs on-site during production.
  8. Jun 22, 2016 at 1:04 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    That's "normal" for this pos Toyota transmission according to Toyota, and Toyota alone....I've got almost 7,000 miles and it still slips, jerks and hunts gears like Helen Keller with a fly swatter.
    And YES my fluid level is correct.
    moab4x432 and Sbpark like this.
  9. Jun 22, 2016 at 1:25 PM
    nyskier
    nyskier New Member
    2016 sr5
    I believe I have read the D to R or R to D hesitation is a built in hesitation
    to let things slow or stop moving before the transmission gearing locks up in the new direction, but don't quote me on that. I had a Honda Pilot did the same thing for 120,000 miles.
  10. Jun 22, 2016 at 1:56 PM
    Retired Heat
    2016 SR5 DCSB 4x4
    Did 12 mile test drive. Got 22 mpg, mostly 40-45 mph two lane. A few stops and one exit on the freeway. Never went over 60. Accelerates MUCH smoother from a stop. Could almost say the issue is completely gone. For now, only 1 test drive.
    The shifting from P>R>D>P seems a little better. What was noticeable was that when it does shift into gear it grabs aggressively. Thats the best way I can explain it. Before it seemed that it slipped into gear. Now it feels like it grabs a gear. More positive I guess.
    Actual driving, I did't really notice anything different. Will see when I take it to work 25 miles or up to the cabin, 83 miles through the mountains.
    This fluid level check process is the single dumbest thing I have ever experienced on any car or truck. It's 95 here at midnight this time of year. If no dipstick, just put a drain bolt and a fill to here bolt. WTH Toyota?
  11. Jun 22, 2016 at 2:24 PM
    Bob259
    Bob259 Well-Known Member
    Arizona
    2016 Tacoma Limited DCSB 4x4 3.5 V6
    Had my serviced today and it was 1/2 qt low. They topped off and reset the ECU so we'll see if it helps. In addition to the R to D delay i was getting a 2-3 and some times 3-4 flair as much as 600 RPM after it sat for an hour or so and only did it once when i first started out, of course they couldnt dulpicate that, or the topping off the fluid fixed it.
    What I still find puzzling is with an over 10 quarts of trans fluid (w/trailer tow) why would we be seeing issues when its only 1/2 quart low, as most of them are showing.
    Retired Heat[OP] likes this.
  12. Jun 22, 2016 at 3:26 PM
    glider_guider
    I would venture to say that you are better off than you were if it dumped less out than you put in, but you may still be low. The reason for the temperature range is that fluid expands as it heats up. If yours was already blinking, that means that it was already at or above the range for the test, which means that it was dumping fluid out that would have stayed in if it was at a lower temperature (i.e. in the range ... solid lit "D"). At the point it starts blinking the fluid is at the minimum acceptable level ... just my thoughts on the situation.
  13. Jun 22, 2016 at 6:15 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    I wholeheartedly agree. The transmission needs a way to check it cold. There is going to be X amount of fluid in it then, so put a freakin check plug in the side....problem solved.
