another backspace question
Discussion in 'Wheels & Tires' started by 3boyztaco, Jun 3, 2011.
  1. Jun 3, 2011 at 3:33 AM
    3boyztaco
    3boyztaco [OP] Well-Known Member
    in the middle of the sea
    PreRunner
    I have been following the many threads on offset and back spacing. It seems that 4.5" bs is the standard for 6"lifted 05+ tacos. Question - how far out of the fenders will a rim 20x9, 4.5 bs, -12mm offset and 275/65/20 vs 20x10, 4.56 bs, -24mm offset same tires, will it rub the UCAs
  2. Jun 3, 2011 at 6:56 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
  3. Jun 3, 2011 at 7:57 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If the rim is the same backspacing but 1" wider, it will stick out 1" further, not 1/2".
    If the backspacing is the same, then all of the increased rim width is on the outer edge of the rim.
  4. Jun 3, 2011 at 8:33 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    If your getting 275's don't buy a 10" wide wheel the side wall is not going to look good, stick with the 9"
    And a 20/9 with a 4.5bs shouldn't stick out much the FJ rims are 8" wide with a 4.5bs and 285's don't stick out too far.
  5. Jun 3, 2011 at 8:36 AM
    KPT
    09 Prerunner
    Yeah you were thinking that for the same offset, the extra inch gets split into two. Backspacing already takes that into account.
  6. Jun 3, 2011 at 10:37 AM
    3boyztaco
    PreRunner
    thanks a lot for the helpful info. guys. it's hard to find pics of wheel and tire shots from above fender. just don't want tires sticking out too far. :)
