Another BHLM/Retrofit thread - My finished product
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EJ_Taco, Apr 18, 2017.
  1. Apr 20, 2017 at 10:51 AM
    #41
    EJ_Taco
    EJ_Taco [OP] Well-Known Member
    Eric
    2016 TRD Offroad
    Lol, exactly my thoughts! BTW pretty much followed your instructions for the BHLM, thanks for all the great info in some other threads here!
  2. Apr 20, 2017 at 10:53 AM
    #42
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    :hattip:
    mateo_roberto likes this.
  3. Apr 20, 2017 at 8:43 PM
    #43
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Alright well I was excited to learn more about the diode dynamics drl and I figured out how to install them with a quick poke and minimal splicing of the harness. Ill make a full write up after install.
    The main thing I learned is that the new drl should only need to run to the old drl & turn signal hot wire, no parking light. The drl has two 12V positive leads and 1 ground, all 3 of which you want to tap into. One of them is for hi-led (low beams off) and the other for dim-led(lowbeams on). These correspond to the red/white wires on the DD drl harness. I'm likely going to cut the female plug from the factory drl and solder it to the DD to make my own pigtail (will find out correct part number) so that 3 out of 4 wires are plug n' play with respect to the factory harness. The 4th yellow wire I'll posi-tap into the right/left turn signals for amber switchback.
    EJ_Taco[OP] and dead.fm13 like this.
  4. Apr 20, 2017 at 9:28 PM
    #44
    MESO
    State of Jefferson
    does the DD board have 4 wires?
    Ground
    Turn
    DRL low
    DRL high??
    Just remember if you splice both factory DRL wires into ONE DD input be sure to diode isolate them, that way there is no backfeed into the other DRL wire(when it is supposed to be off)
    Edit.. I didn't read the entire post.. gusss they do,, sweet! Plug and play(well solder) then just tap the turn signal
  5. Apr 21, 2017 at 7:02 AM
    #45
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    Thanks for the info! Looking forward to the write up. Hope the install goes well for you. I think that making your own pigtail is smart, and probably the route i'll go as well.
  6. Apr 21, 2017 at 7:34 AM
    #46
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    @MaxxTRD Did you do something similar to this?
  7. Apr 21, 2017 at 2:53 PM
    #47
    MaxxTRD
    MaxxTRD Well-Known Member
    Maxx
    Seattle
    2016 Tacoma Off Road
    King Extended Travel Coilovers, Total Chaos UCAs, Rear Kings with Icon AAL, Cab mount Chop, 305/70/16 KO2s Moto metal wheels CBI Off Road Fab bumper and sliders Rad industries grill
    yeah i did but i just added halos i didnt mess with the projectors
  8. Apr 22, 2017 at 8:41 AM
    #48
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Both housings opened up, did one last night and one this morning, no serious issues that the heat won't fix putting back together. Funny, last night it took me about 2 hours to get the first one open and this morning it took about 15 minutes.
    Time for the fun part!
    Optimaltaco likes this.
  9. Jan 21, 2018 at 6:20 AM
    #49
    Lucifer29
    Lucifer29 Well-Known Member
    Red
    Are you guys prepping the chrome surrounds by scuffing or just painting direct over the shiny surface?
  10. Jan 21, 2018 at 6:43 AM
    #50
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Very light flash coat. No stuffing needed.
    Lucifer29[QUOTED] likes this.
