Another Bilstein 5100 lift question(s), with 885 coils
Discussion in 'Suspension' started by NBBAZ, Sep 12, 2015.
  1. Sep 12, 2015 at 10:27 PM
    NBBAZ
    NBBAZ [OP] Well-Known Member
    Arizona
    2010 Toyota Tacoma DCSB Sport 4x4
    I've been searching, what seems to be endlessly, for answers to questions I have regarding some Bilsteins I picked up a while back. I got a smoking deal on them assembled and I have a 1/4 inch spacer to correct the drivers lean. I can't seem to find the answers I need, so here it goes...
    I have a 2006 DCSB Sport 4x4. It's all stock. I want to install Bilstein 5100s set at lowest setting with 885 coils.
    Questions:
    1. How much lift will 5100s at lowest setting w/ 885s give my '06 DCSB 4x4?
    2. If the lift is more than just leveling, how do I make the rear suspension match? What are my options?
    3. With 5100s at lowest setting and 885s will I need UCAs to keep angles correct?
    Please keep in mind this is a daily driver, I don't want to upgrade to kings or icons etc. I just want my taco to be level with this set up.
    Oh yeah, trolls need not answer.:D Or, did I just ask trolls to answer?:crapstorm:
    Thanks!
  2. Sep 12, 2015 at 10:29 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Trololol
  3. Sep 12, 2015 at 10:33 PM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    They will give you a bout 2.5 inches of lift. Right on the border line of needing new ucas
  4. Sep 12, 2015 at 10:38 PM
    NBBAZ
    Arizona
    I was afraid of that.
    I was afraid of this more. I was hoping to avoid spending the extra cash for UCAs, but I want/need my truck to be right.
    What are the options for equaling the 2.5 gained in the front for the rear?
    Bennett707[QUOTED] likes this.
  5. Sep 12, 2015 at 10:45 PM
    DirtyTerp
    Randy
    Freeland, MD
    '14 DCSB MGM
    Whatever you do to the rear won't matter what you do to the front. If you did 885's they'll give your around 2.5 inches of lift. Depends if you want to bro lean, level, or give your truck the rake back for your options for the rear
  6. Sep 12, 2015 at 10:51 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You will definitely want UCAs if you're around 2.5 inches.
    Wheeler's 3 leaf AAL is nice in the back if you aren't carrying a lot of weight. 1.5-2" lift depending on how you choose to install. $150 or so.
  7. Sep 12, 2015 at 10:55 PM
    NBBAZ
    Arizona
    I'm looking to have the truck sit as level as possible.
  8. Sep 13, 2015 at 5:48 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Are your leaf packs original?
    If so, I wouldn't add an AAL to them. I'd replace them.
    General HDs or Wheeler's HDs should get you very close to level with 885s up front.
    Yes, you'll want UCAs. I have 884s and I'm just barely okay.
  9. Sep 13, 2015 at 5:58 PM
    NBBAZ
    Arizona
  10. Sep 13, 2015 at 5:59 PM
    NBBAZ
    Arizona
    Yes, leafs are original. We'll worn with 160k plus! HD? Not sure what HD is?
  11. Sep 14, 2015 at 5:05 AM
    js312
    Joe
    New England
    "Heavy Duty"
    They handle more weight and consequently raise the back end over stock.
    General Spring
    http://www.generalspringkc.com/product_p/90-297hd.htm
    Keep in mind that price is per leaf pack so you'll need two. You'll also need new u-bolts, around 7" long. U-Bolts will probably run you about $30 for four and you can get them from General, Wheeler's, or have a local shop make them for you.
    Wheeler's These include everything.
  12. Sep 14, 2015 at 5:27 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    New leaf pack. At this point, anything you add to those will be a bandaid
  13. Sep 14, 2015 at 5:41 AM
    tommyhd03
    tommyhd03 Well-Known Member
    tommy
    spartanburg
    Sport Tacoma double cab long bed
    885 coils, blistein 5100 front and rear, 1 1/2 AAL. SCSI sr8 wheels, 285/70/17 cooper discover at3 tires.
    I did 885 with 5100 and 1 1/2 AAL
    Got 2 1/4 In front and almost 2 in back. Alignment in spec.
    Dr. Jekyll likes this.
  14. Sep 14, 2015 at 7:35 AM
    js312
    Joe
    New England
    Other option: Is your truck covered in the leaf spring recall?
    If so, wait to get brand new Toyota 4-leaf packs then pull them apart and add an AAL to the pack.
  15. Sep 14, 2015 at 7:37 AM
    geekhouse23
    I had an AAL before the Dakars and it rode more harsh than the Dakars. The AAL rode rough and I replaced it after 3k for the Dakars. If you are going AAL at least look into the progressive AAL pack. You will thank me.
