Another Bilstein 5100 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonah, Jan 25, 2017.
  1. Jan 25, 2017 at 6:23 AM
    Jonah
    Jonah [OP] Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I'm having new shocks installed tomorrow and I want to make sure they're set up correctly. My truck (2007 TRD O/R 4x4) sits perfectly level now, as checked with a 4' level on the bed rails. It's all stock suspension with the leaf spring TSB installed. Right now, the front is about 1" less than the rear measured from the hub to the wheel arch.
    I'm not looking for any kind of lift and don't want to install spacers anywhere. So, the question is, should I set the front shocks to 0 or .85?
  2. Jan 25, 2017 at 6:26 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    you know the answer...
    if you want no lift from where you are now you set at zero
  3. Jan 25, 2017 at 7:32 AM
    Jonah
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    Thanks, it does seem kind of obvious. With everyone talking about using .85, I wasn't sure if somehow the 5100s were shorter than the stock shocks.
  4. Jan 25, 2017 at 7:53 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Most people installing the 5100's are interested in the lift aspect, which is why you see so much mention of the different perch settings.
