Another blown engine? M.O.R.R.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skydvrr, Mar 9, 2022.
  1. Mar 10, 2022 at 4:07 PM
    #161
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
  2. Mar 10, 2022 at 4:08 PM
    #162
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    LoL! True, but I'm close to the point where Toyota can't tag in.
    Thunder Fist likes this.
  3. Mar 10, 2022 at 4:08 PM
    #163
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    As you acknowledged, I'm not concerned about blow-by. I've definitely had my truck in the "bad" types of steep orientation in the last year, and I plan to continue doing that kind of driving, so I like the idea of having a bit of a buffer before cylinder 6 starts chugging 0W20 and trying to escape the block.
    tacoman45 and tonered[QUOTED] like this.
  4. Mar 10, 2022 at 4:10 PM
    #164
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    In normal driving, it is said that you only have to empty it at normal service intervals. In my past experience, that is mostly foam / water, not liquid oil.
  5. Mar 10, 2022 at 4:27 PM
    #165
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol
    tonered[QUOTED] likes this.
  6. Mar 10, 2022 at 4:36 PM
    #166
    Colorado Truck
    Colorado Truck Active Member
    Chuck
    1995 Tacoma V6, 5spd 4wd
    99 4-runner engine V-6 2007 Tacoma rims Late 1st gen electric side mirrors (and interior switch) Fabtech add a leaf lift Hella headlight housing for bulb only replacement SickSpeed "old school" gear shift knobs
    So the truck is fine thanks to the special features. But, how do you stand up on that hill when you get out?!? LOL
    Stocklocker[QUOTED] likes this.
  7. Mar 10, 2022 at 4:55 PM
    #167
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hear you.
    :cheers:
    hiPSI[QUOTED] likes this.
  8. Mar 10, 2022 at 5:10 PM
    #168
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I’m in there. I’m only 4’3” so can barely see over the dash.
  9. Mar 10, 2022 at 5:50 PM
    #169
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I'm orginally from WV. One leg is naturally longer than the other due to growing up in the hills.
    Our football fields were terraced...
  10. Mar 10, 2022 at 5:58 PM
    #170
    Stocklocker
    17TRDORDCSBAT
    As in a single field terraced at the 50 yard line, or different fields at different levels?
  11. Mar 10, 2022 at 7:14 PM
    #171
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Hillside Guyser, we call em.
  12. Mar 10, 2022 at 7:20 PM
    #172
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
  13. Mar 10, 2022 at 7:41 PM
    #173
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Where's that 3.0 3VZ-E? :rofl:
  14. Mar 10, 2022 at 11:00 PM
    #174
    Stocklocker
    17TRDORDCSBAT
    Those guys should be running through a swimming pool full of rust. Old Toyotas had nice engines, but the rest was hot garbage.
    44-16 Taco and tacoman45 like this.
  15. Mar 10, 2022 at 11:08 PM
    #175
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    After doing the headgaskets in a 93 4runner for the 5th time in its life.
    We like to forget about that one
    now the 3vz-fe? Just as good as the ol 5vz
    all that being said the 3.5 isn’t bad. It’s just all the extra shit strapped on it that makes less forgiving on oil issues.. WAY more stuff going on in this head than the Toyotas of old. The old bucket and shim valve trains can run on like no oil. Which is why fighter planes from the Second World War had similar setups
  16. Mar 10, 2022 at 11:15 PM
    #176
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    :welder:
  17. Mar 10, 2022 at 11:16 PM
    #177
    TriniPhantom
    TriniPhantom Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    So from my understanding after reading through these threads, on a steep incline the oil catch can will help keep oil out of the intake...until it gets filled up. The oil catch wouldn't help on a steep decline. My question is would baffles in the oil pan help in both cases (incline and decline)? If so, are there any drawback to installing baffles. One thing I could see is that it would take up space and reduce the volume of the oil pan.
  18. Mar 11, 2022 at 12:05 AM
    #178
    Empty_Lord
    Dan
    A baffle sold by Wilhelm for the 2nd-fe has proven to help oil pressure in racing due to keeping oil by the pickup, but the design in the fwd oil pan is pretty different from the trucks. The main issue here is the oil pools up in the head at too steep of an incline. Baffle won’t help since the oil is still going to be pumped up to the head.
    A dry sump oil system is probably the only full proof way to fix this issue.
  19. Mar 11, 2022 at 5:30 AM
    #179
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    be careful not to do what someone on a forum came up with to do. You could be making things worse. The real cause of any problem is still known. That there is an actual problem is also still unknown. A, not even handful, of failures out of a few million trucks is not enough of a pattern to matter at this point. There is to much guessing on the problem. Like I said, I have seen countless 3rd gens go up that exact spot with no issue, so there is literally no proof of anything yet. It is just as likely that the gearing is at fault with bigger tires, causing a heavy load at low rpm on the engine, which is a bad condition.
  20. Mar 11, 2022 at 11:04 AM
    #180
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    Yeah they get more and more complicated every year. They were technologically amazing before and are even more so now. Warning to those just tuning in: that may not be what you're looking for in a vehicle. Buy something else!
    Toyota designs vehicles for the 99% use case. There's no point in designing it for the 1% of people (probably even less) that will heavily modify and push the vehicle to the extreme. Gone are the days when everything is over-built. We have better tools to do better analyses and manufacture more precisely. Over-built is less efficient and more expensive. And that is something Toyota knows very well.
    The user shouldn't expect that every vehicle should be able to handle the extreme. May be it's an unpopular opinion, but if you're at an extreme angle while rock crawling, and your motor drowns itself in oil, Toyota is 100% within the right in saying that is an example of mis-use. They aren't responsible for every scenario. If you want to do that with your Tacoma, then expect to have to fix it. If you aren't sure if the 3.5L can handle it, then get a different rig w/a tried and true motor. Shit breaks when you push it beyond its design intent.
    /rant
