Another Brake Control ?
Discussion in '4th Gen. Tacomas (2024+)' started by TOMRR, May 21, 2025 at 8:55 AM.
  1. May 21, 2025 at 8:55 AM
    TOMRR
    TOMRR [OP] Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    I have a 2024 Tacoma Base Off Road with no Factory Brake controller. I have checked and I do have the Blue Brake wire that runs to the large plug in the rear. I know Toyota does not recommend and aftermarket brake control with the factory controller installed on truck. I don't So can I install and aftermarket on mine without any issues??
    Tom C.
  2. May 21, 2025 at 11:32 AM
    Stripgear
    Stripgear Member
    TX
    Tacoma SR-5
    I installed a Prodigy on mine. You can tap into the blue wire under the passenger seat. I tapped into the 3rd brake light with a diode for the trigger wire and the unused air compressor wire for power. It works fine but is more work than it should be. There are several threads on this site and a good one on the "other " site to help you.
