Another broken antenna thread...this one with a twist!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RichP, Sep 19, 2012.
  1. Sep 20, 2012 at 3:20 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Hmmm... I took a small drill bit and drilled into the bolt and then once the bit caught onto the bolt and started screwing in. I reversed the drill and it just unscrewed the bolt. I guess I got lucky. Oh yeah it was a right hand bit because I didn't have any left hand ones
  2. Sep 20, 2012 at 3:22 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Slllllooooowwwwwww cuts better when drilling a harder material
  3. Sep 20, 2012 at 3:23 PM
    Drunknsloth
    Retribution
    South West
    Yep slow and pressure
  4. Sep 20, 2012 at 3:41 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Nope. You are not the only one. *goes runs out to check it*
  5. Sep 20, 2012 at 3:45 PM
    babytruck
    NorCal
    Yep. It was loose again. I'm gonna go use some plumber's tape.
  6. Sep 20, 2012 at 4:00 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    dont do that youll be insulating it from its connection lol. dab of loctite works...just on the top
  7. Sep 20, 2012 at 4:58 PM
    babytruck
    NorCal
    I just went out to check it (thank you) and so far the radio is getting reception good (is that what you meant?) . I just put it in the threads, not the end.
  8. Sep 20, 2012 at 5:11 PM
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    What about a 6mm wrench and tighten it? :notsure: worked for me
  9. Sep 20, 2012 at 5:24 PM
    babytruck
    NorCal
    Still would come loose. I tighten it so much there's marks on the base from the wrench.
  10. Sep 20, 2012 at 5:24 PM
    PAlittlematty
    Beech Creek, PA
    I miss my taco
  11. Sep 21, 2012 at 9:27 AM
    shemp
    shemp Well-Known Member
    I used loctite on mine.
  12. Sep 21, 2012 at 3:22 PM
    babytruck
    NorCal
    You guys are not going to believe this but I swear on my truck that this is true. There's this spot that I travel through that for about one mile I get nothing but static on my radio. It's on every channel.
    But today on the way to work and on the way back, the music never stopped!! So I'm thinking that either it never was connecting right or that tape is magical!
  13. Sep 25, 2012 at 11:29 AM
    TheGrinch
    TheGrinch Cheese Head.
    Sean
    RP, CA
    07 TRD DCSB OffRoad on 33's
    6" procomp lift
    thanks man, let me know what you end up doing.
  14. Sep 25, 2012 at 4:07 PM
    Brandon###
    Brandon### Well-Known Member
    my antenna snapped off when i was going to remove it BEFORE i went throught the car wash. It immediately broke as soon as I applied pressure to it. I guess it had corrosion and was seized onto the post.
    Anyone have a hookup with a Toyota parts dept?
  15. Sep 25, 2012 at 4:12 PM
    #35
    skeeet
    skeeet Well-Known Member
    Pete
    San Jose, CA
    05 DCSB TRD Sport
    Mine was also stuck, so i placed a flat head in one of those notches and whacked it a few times, it loosened and i twisted it off
  16. Sep 25, 2012 at 4:37 PM
    #36
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you Sure that is an antenna? Looks like something else! :p
  17. Sep 25, 2012 at 5:56 PM
    #37
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    Where did you get that stubby? How is the reception?
  18. Sep 25, 2012 at 6:03 PM
    #38
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I simply used a little epoxy on the flat end of a drill bit, let it set up for a few minutes and the twisted it right out, no problem. slick as shit!:D
  19. Sep 25, 2012 at 6:04 PM
    #39
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    Where you get that antennna?:D
  20. Sep 25, 2012 at 10:26 PM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I will never ever use a grabit bit ever again for this reason alone, I had a broken bolt recently that the grabit bit broke off in and looks exactly like this now. I tried drilling at it all day as well and ended up with something that looked exactly like this. I really don't know what to do at this point other then take the dremel to it, but I'm not sure if the carbide burr bit would even work. I wonder if the diamond cutter bit attachment would work at all because I think I have one of those lying around for sure.
    EDIT: come to think about it, if I had a fine point grinding stone attachment on the drill or dremel that day I probably could have grinded through all that material, because one of my larger stones was grinding past the material of the grabit junk bit. OP, you very well might want to consider the carbide burr dremel attachment suggestion and let us know what happens.
