Another CB antenna mount question.
Discussion in 'Audio & Video' started by Rellik01, Feb 3, 2012.
  1. Feb 3, 2012 at 2:51 AM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Just picked up a Firestik door jamb mount for a CB antenna. Will there be a grounding issue if I mount behind the tailgate area (where the taillights bolt into)
  2. Feb 3, 2012 at 3:27 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    If there is any RF grounding problem (very likely), you can always run a grounding strap (flat braided wire) from the antenna mount to the truck's metal frame (or a bolt connected to that frame). While this isn't exactly ideal, it will probably lower your SWR readings to a reasonably acceptable level.
    By the way, make sure to use a braided wire grounding strap instead of simple wire. The latter will have too much resistance to properly accomplish this particular goal. At the same time, keep that grounding strap as short as possible, again to reduce resistance.
  3. Feb 18, 2012 at 7:42 AM
    fau8823
    fau8823 Well-Known Member
    Tom
    Hampton Roads, VA
    2010 Tacoma Sport 4x4
    Tint-20%, Kenwood 2 meter radio, firestik 2 meter antenna on a BAMF tailgate mount, Extang Solid Fold , Pioneer bhs-3500 HU, clazzio leather seats, Scangauge II
    Did you end up doing this install? How'd it come out? Pics?
