Another dead battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Feb 18, 2019.
  1. Feb 20, 2019 at 8:40 PM
    #121
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I changed to this PID but it’s not as easy to monitor this way, or it could likely be that I just don’t understand what I’m looking at. Am I supposed to calculate on the fly and in my head the displayed percentage of an unknown voltage? What am I missing? I’d rather just see a voltage output.
  2. Feb 20, 2019 at 8:43 PM
    #122
    Rujack
    Mine is showing a constantly fluctuating value of anywhere from the teens to ~ 70, so this can’t be voltage :eek:
  3. Feb 20, 2019 at 9:28 PM
    #123
    ferntr33
    ferntr33 Well-Known Member
    That’s globalism. I have heard since optima is made in Mexico now they suck. I’ll bet CA made some mandate requiring less lead in batteries and rest of country followed. Lead birdshot shot is illegal now too.
    Is there a list of made in USA batteries anywhere?
  4. Feb 20, 2019 at 9:39 PM
    #124
    Bishop84
    Bishop84 Well-Known Member
    I swear by Interstate, they have the best warranty and I believe 90% of them are USA made, they have to be indicated with a special sticker for the Mexican ones. We sell them in Canada and can warranty them in the US on a road trip, thats freaking awesome.
    Shelf Life likes this.
  5. Feb 20, 2019 at 10:13 PM
    #125
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    One reason I switched out the power plugs for more switch locations was to have a dual usb/voltage display so I'd know what the battery and alternator were doing. Bought the truck used a bit less than 2 years ago and I believe they put new shoes and a battery in it. The alternator gets the display up to ~14.2V. 24F so no tow package but someone installed the hitch and bumper plug. Checking out that wiring is on the todo list before towing.
  6. Feb 21, 2019 at 12:03 AM
    #126
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yes it was directed towards you. I thought I seen a light bar so that’s why I said that. Realized it was just a rack. But I also see you have a solar setup. I do remember reading a post where you mentioned it I believed. Can’t remember if you said it was for an auxiliary source or is connected to the trucks electrical. Either way it could easily be a factory component that failed, or is staying energized. Or like I said, if you only do short trips around town and or don’t drive the vehicle much, it may just not be getting a long enough charge while driving and it’s finally started to take its toll on the battery. Also make sure the top of the battery is clean and free from debris. This, coupled with vented acid and chemicals from the battery can cause a parasitic draw. There are lots of possibilities. The battery could truely be bad and is reading ok on their tester. Usually they have 2 different machines for the battery test. They sometimes have a hand held one that prints those receipts too. Those don’t work as good as the big stand up ones that also charge the battery. Usually the big ones charge the battery and then kinda idle until the battery is back at a normal temp after recharging, then it will perform the the test. Not sure if their machine is set up that way or if they ended up using a handheld one. That’s how it was at the Honda dealer I worked at anyway.
    If you check for a draw and there are no signs, then I would try and trickle charge it overnight (removed from the truck) and then first thing in the morning see how it fires up. Then (if ones close) I would drive it to autozone or advance auto and have them do a free battery check on it after it’s been fully charge. That way you should get a lot more accurate of a reading.
  7. Feb 21, 2019 at 6:26 AM
    #127
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    If you go with the Odyssey 34R, Amazon has the tray for 8 bucks. They have the battery for 295.00 I think that's the direction I'm headed soon. My stock Batt is going on 3 1/2 years.
    G.
    shakerhood[QUOTED] likes this.
  8. Feb 21, 2019 at 6:37 AM
    #128
    pughfish
    pughfish Well-Known Member
    William
    Fayetteville, NC
    2024 Toyota Tacoma Limited
    What is the warranty on stock batteries?
  9. Feb 21, 2019 at 6:42 AM
    #129
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    oops, I was mistaken it is actually a percentage. I told you I don't use it much lol.
    Here is an old screen shot from mine.
  10. Feb 21, 2019 at 6:51 AM
    #130
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Just sent to the service manager at the dealer I bought truck from. Included a letter stating the circumstances and need to get truck fixed ASAP. Included copy of receipt from Advance Auto and picture of battery installed. They sent documentation to Toyota who approved payment and check came direct from dealer to me.
  11. Feb 21, 2019 at 7:23 AM
    #131
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    What’s that app you’re using?
  12. Feb 21, 2019 at 7:26 AM
    #132
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    OBD Fusion
    Kremtok[QUOTED] likes this.
  13. Feb 21, 2019 at 7:33 AM
    #133
    Dravnx
    Dravnx Well-Known Member
    jeff
    Santa Rosa, Ca
    2018 SR5
    AGM batteries do not develop a memory. They are still lead acid batteries with a glass mat to contain the acid.
  14. Feb 21, 2019 at 7:46 AM
    #134
    Rujack
    Some of the PIDs have confusing names. If anyone knows which one measures alternator voltage output please let me know...
  15. Feb 21, 2019 at 7:47 AM
    #135
    Rujack
    I believe 3/36 direct replacemnt
    shakerhood likes this.
  16. Feb 21, 2019 at 8:07 AM
    #136
    Rujack
    Any reason I shouldn’t temporarily install without a tray besides the risk of the battery moving?
    I’m not sure if I’ll use a 2gen tray or make one. The only benefit to using an aftermarket tray would be if the tray mounts to the truck with hardware, and the j bolts then attach to the tray instead of putting that tension on the sheet metal in the stock locations. Am I missing anything?
  17. Feb 23, 2019 at 10:00 PM
    #137
    bagleboy
    Scott
    Norcal, Santa Rosa
    Bad if you hit a bump and it's loose.
  18. Feb 23, 2019 at 10:10 PM
    #138
    Rujack
    It’s pretty snug
  19. Feb 23, 2019 at 11:35 PM
    #139
    Ziggyman
    Ziggyman Well-Known Member
    2018 TRD OR DBL 4x4
    We had a bit of snow where I live, first time in decades really. Going to pick up the kids from school, pass the Arco (place is empty) but I know the Costco down the street is cheaper. I go there and it is packed 5 cars deep, why? U turn, Pick up the kids and go to the empty Arco. Best 10 cents a gallon I've ever spent. Even if it is shit.
  20. Feb 24, 2019 at 4:34 AM
    #140
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Im on my third battery in 5k miles on a new truck. 1st died at 3400 miles, second 5 weeks later at 4400 miles and now the third has it resting voltage dropping. Its now at 11.9 as resting voltage, (Other batteries did same from 12.3/4) (current battery 5 weeks old) meaning it will be dead again and leave me stranded again shortly. Once it gets to 11.6v the truck wont start since their is so many things that turn on as soon as you open the door, even the hood open draws current with the stupid sensors everywhere. It takes Toyota 4 hours to do a GD load test, done this twice now. They have no idea why. Alternator is fine, toyo cant do anything unless its on fire or their are tons of dummy lights on. Just keep telling me to bring it in when it dies. Thanks. Its ok though Toyota told me that 11 volts is an acceptable voltage for these batteries.
