Another Door Lock Actuator *patch* thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kwade, Dec 23, 2012.
  1. Dec 23, 2012 at 12:26 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    Over on the TechChat forum, I made a couple posts about a taco lock actuator failure.
    I promised to teardown and patch attempt this weekend.
    I did and I got a few cellphone pics.
    I don't have time right now to get everything properly posted here, so I'll do it in stages. Hold on. I have about 15 pics to show.
    Then add some commentary and link the tumbs to full size pics.
    I do have a photobucket account, so I'll use that.
    First, the actuator, still connected by mechanical links.
    Link connector cover open
  2. Dec 23, 2012 at 12:34 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Or get tapatalk app,real easy posting pics then.
  3. Dec 23, 2012 at 12:36 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    Thanks K
    I'll look into it. I have the photobucket pics ready, just working them in to my time
    Coolerman likes this.
  4. Dec 23, 2012 at 1:12 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    Actuator assembly case cover removed
    The prize. Now to remove it.
    I removed the switch assembly to get the motor electrical connectors out of the way. two screws (Not the one holding the switch down.)
    Switch assembly and actuator with motor removed
    th_ElecAssy_zps6f20137e_13ae30e91c2f185cd33e78df3b62820dee5ca4f4.jpgth_Actuator_MotorRemoved_zps6ba5d601_bdf25c5c5abd11f1b11b6efb82845e363196f0ca.jpg
    The prize with embossed info VD297427 made in Vietnam
    th_MotorampGear_zps6968f42d_847a18bf532e478d3d8f8d9f331c4cb9b8b1f44b.jpgth_MotorEmboss_2_zps26ce400d_337a980e920f01efd83114f7a10e00abe0774a9f.jpg
    Commutator end.
    Now to crack this nut.
    Pry up the locking tabs from the grooves
    difficult . you can see the chewed up metal in this pic
    Problem. Burned Commutator bars.
    I used some fine sandpaper to burnish the bar surfaces.
    I did NOT have very fine, so I folded the sandpaper in to a long thin
    strip and gripped it about 2 inches away from the commutator so as NOT to scratch the copper too much.
    I polished the resulting surface with grocery store paper bag. Comm is a bit out of focus on the AFTER pic.
    Before and after
    th_Comm_Burn_zpsc6f585a5_f95776ae93d9bc8e653e3ca1d2c5b2b98bbaed88.jpgth_Comm_Burnish_zps0692ccb4_86e6f4fdc74ca9e995fa799a3c7a589845760271.jpg
    Brush housing
    Now to reassembly......
    I tried several approaches.
    1. Removing the bushing and plastic washer from the shaft at the commutator. I placed the bushing and washer in the comm housing and attempted to finesse the comm between the brushes and then into the hole in the housing. Did not work!
    2. Insert narrow piece of cardstock between the brush holder, insert comm and remove cardstock. Did not work!
    3. Same as #2, except using very thin plastic (very thin water bottle). Same result as #2. Did not work!
    4. Pull the gear about 1/2 inch away from the motor housing.
    Mine would slide down the shaft, so this was easy. It made a bit of viewing room at the comm end during assembly.
    Insert this into the motor shaft hole in the brush housing.
    Then insert the commutator part-way into brush assembly, slowly, gently rotating the curved pick (thanks Pugga) to cause the commutator brush spring clips to get out of the way of the comm while pressing slightly on the top of gear.
    Once seated, I pressed the gear back to original position.
    I ohmed the motor for connection, the put the DMM in volt mode and spun the motor. The generated voltage confirmed the connection.
    I removed the DMM and spun the motor a bit to aid in brush seating.
    I reassembled all of the bits, taking care to place the blue bar back and the switch arm where they belong. You can see the blue bar in the second pic, under the switch arm, and in the third pic at the top.
    I put the case back together and inserted the electrical connector to test it. It did not work.
    But then, nothing else worked. My battery had died overnight! :eek: I guess the door being open for a while was enough to finish the battery. It was the original Toyota/JohnsonControls battery from 2008.
    I charged the battery for several minutes and rechecked. The actuator worked. It was slamming the actuator in and out of lock position. I remounted the lock actuator and left to buy a new battery!
    Thanks TW. Now I just hope to get a few years out of this patch!
  5. Dec 23, 2012 at 1:17 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Good write up,thanks for sharing.
    BassAckwards likes this.
  6. Dec 24, 2012 at 8:41 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Thanks for the write up and pics Kwade - Good job!! Hope they work for another 200,000 miles.
  7. Dec 24, 2012 at 8:43 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Cool, I have had 3 of the 4 in my truck replaced, they were replaced before I bought it, but I figure it is only a matter of time...
  8. Dec 24, 2012 at 1:24 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    YOU are welcome, Kolunatic!
  9. Dec 24, 2012 at 1:25 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    Thanks for the kind words.
  10. Dec 25, 2012 at 7:31 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    Small update.
    I mentioned earlier that I had to replace my battery. Now I have to kill the seatbelt chime again.:(
  11. Jan 16, 2013 at 3:29 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    I hate to say it, but it didn't last a full month. It is back!
  12. Jan 16, 2013 at 3:59 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    after a year of not working, the last two weeks my drivers side actuator started working again - but as of yesterday it stopped again. :(
  13. Jan 18, 2013 at 8:05 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Mine have been making an intermittent grinding noise onthe dr rear door for a whole now. Sound much more like a stripped gear in my case tho. Did yours make any noise before they failed?
  14. Jan 18, 2013 at 8:26 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    No grinding noises, just stopped one day.
  15. Jan 18, 2013 at 8:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I did this fix a while back, almost a year ago and they are still going strong. My driver's side lock would not react at all, I had to manually lock and unlock it. I tore everything apart and cleaned it with CRC Electrical Cleaner (red can, looks like Brakleen). Everything is still working perfectly.
  16. Jan 19, 2013 at 3:20 PM
    kwade
    kwade [OP] Member
    kwade
    sc
    08 taco DC
    CtTaco,
    No grinding. The sound like a double-push of the LOCK button is what I heard.
  17. Feb 4, 2013 at 11:52 AM
    RichieW13
    RichieW13 Well-Known Member
    Richie
    Thousand Oaks, CA
    2008 PreRunner Sport
    I fixed my driver door about 10 months ago. It has just stopped working again.
    Also, my left rear door stopped working a couple months ago.
    This is so annoying. Have any aftermarket companies come up with a better design?
  18. Feb 5, 2013 at 7:11 AM
    CtTaco
    Eric
    Connecticut
    Mines still under warranty thankfully. I doesn't do it all the time so it's been hardto make it happen infront of them but a least its on the books as being a problem so if it fails after warranty it's been well documented (I hope :D )
  19. Mar 11, 2013 at 7:11 PM
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    I have 3 of 4 not functioning properly. I tried to get mine apart but couldn't get the case apart to get to the motor without breaking it. Probably doing something wrong but I'm not sure. 5 galvanized screws and 1 black screw. Got all the clips seperated but couldn't get it to pull apart. I can get the front actuator at cost though a buddy for $200. Are any of the aftermarket actuators worth anything? Seems like I saw some of those for around $60-70. I would rather fix mine but I'm not having much luck. Any help?
  20. Nov 20, 2013 at 3:25 PM
    RichieW13
    Richie
    Thousand Oaks, CA
    How many of you have taken apart your actuators only for them to quit working again a few months later?
    I now have 3 doors that don't work. Last time it took me at least 2 hours to remove, clean and reassemble ONE actuator. I'm not looking forward to a 6-hour project, only to have to do it again a few months later.
    So frustrating.
