Another flashing 4x4 light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boatytoom, Feb 14, 2021.
  1. Feb 14, 2021 at 3:38 PM
    Boatytoom
    Boatytoom [OP] Member
    Jeff
    07 Access Cab with trd package 6 spd Manual
    I know. I know. Its been asked 1--- times. My 07 Tacoma 4.0 has a flashing 4 wheel symbol. Its the light BELOW the Green light that comes on. My 4wd Engages in 4 HI AND 4 lo But it has a flashing red light below that wont quit flashing. Doesnt matter what the selector mode is in. It DOES engage AND disengage. I just have the light that wont go out. It is very cold here, but its been on for a couple weeks. I brought it in the shop to thaw today but didnt help. Is something not completely disengaging???
  2. Feb 14, 2021 at 3:41 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I see your profile says your truck is a TRD offroad. Perhaps the electronic locker button is on. I can't remember where that indicator was located on my 09 TRD but it will flash red when not engaged and the button is on.
    EDIT: The red light indicated in this photo shown here?
    TnShooter and whatstcp like this.
  3. Feb 14, 2021 at 4:11 PM
    Boatytoom
    Jeff
    I will definately give that a try in the morning. Come to think of it, Its been flashing since I tried the locker button the other day
  4. Feb 14, 2021 at 4:18 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    You never shut it off. Locker only works in 4LO. Put it in 4lo and lock it. Unlock it and switch back to 2wd it should turn off.
    TnShooter and deanosaurus like this.
  5. Feb 14, 2021 at 4:24 PM
    Boatytoom
    Jeff
    Problem SOLVED. Thanks a Million Guys
    MurderedTacoV2, TnShooter and Delta09 like this.
  6. Feb 14, 2021 at 5:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What was the problem?
  7. Feb 14, 2021 at 5:05 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Witch.
    Awesome problem diagnosis level 100
    Delta09[QUOTED] likes this.
