Another Frame corrosion question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXTaco211, Oct 24, 2022.
  1. Oct 27, 2022 at 9:54 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    specifically the warm weather 12 years if theres rust/hole = frame replacement...
  2. Oct 27, 2022 at 11:51 AM
    TXTaco211
    TXTaco211 [OP] Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    Thank you for this I will definitely look into this more.
    * Already sent another message with what you sent me and picture of said hole. So now I will wait to see what response I get.
  3. Oct 27, 2022 at 2:02 PM
    TXTaco211
    Corpus Christi, Tx
    Well strike out on first conversation as the representative clearly did not know how to read properly and kept trying to say because my vehicle didn't get the CRC coating in the time frame allotted it did not qualify. So a supervisor is supposed to be calling me back tomorrow.
  4. Oct 27, 2022 at 3:15 PM
    TXTaco211
    Corpus Christi, Tx
    So I took the CSP to my dealer and I have an appointment on Tuesday to get the truck inspected. Thank you @MSgt O for the information. I am still waiting on a call from a supervisor at corporate tomorrow to let them know how poorly there reps can read and interpret black and white of their own service directive. I will keep you guys posted on progress.
  5. Oct 27, 2022 at 4:09 PM
    MSgt O
    2013 Tacoma
    good luck man!!
  6. Oct 27, 2022 at 4:34 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I would fight them . Only if you want to keep the truck . You do wonder if this truck was ever submerged in salt water. This does seem like a good amount of rust for where you live . Now if you were up in New York like me then yes .But Texas? Even being close to the water
  7. Oct 28, 2022 at 6:18 AM
    TXTaco211
    Corpus Christi, Tx
    If it had been driven through water I would have rot all over the body pnls and the body is fine and quite frankly I think if the previous owner would have taken some preventative measures the frame would be good as well. You see idiots that drive into the water and through water hauling butt all the time down here on the beach and then you see the vehicles start to rot like crazy shortly after. I don't get why you would do that to a vehicle you are paying good money for. I feel my truck is very solid for one that has nearly 200K on the clock. I have started replacing stuff not because they have failed but generally as I know they have served their life and I would rather replace before I push it and get stranded due to a break down.
    Before this I had an 04 Silverado that didn't have any undercoating and I had gotten stuck in some brackish mud that didn't have near the corrosion that this truck has but I always take care to crawl under and wash everything with fresh water and spray down after my stupid ventures when I was younger and dumber. When I got rid of it in 2017 it was still in good enough shape to get 10K out of it due to the low miles and condition.
  8. Nov 1, 2022 at 5:23 PM
    TXTaco211
    Corpus Christi, Tx
    Took the truck in to Toyota today for the inspection they sent off the results for approval. So now we wait to see if the powers that be approve the frame replacement.
    They supposedly found my valve covers leaking haven't looked to verify yet, timing cover gasket and what I am assuming is the oil pan but they said crank case. So I will probably have them do the oil pan and timing cover while they do the frame. And maybe save a couple dollars on labor as they will have easy access with the motor out. But we will see what the verdict is hopefully tomorrow.
    DES2009 likes this.
  9. Nov 1, 2022 at 6:27 PM
    Buzzkill657
    Buzzkill657 Well-Known Member
    Jeff
    this is correct. I just bought a tacoma from Louisiana this summer. I live in Indiana and my dealer would not do the recall until i registered the truck up here
  10. Nov 3, 2022 at 8:21 AM
    TXTaco211
    Corpus Christi, Tx
    Just got the approval for the frame replacement from Toyota finally something good happen after my streak of bad luck lately.
  11. Nov 3, 2022 at 8:57 AM
    MSgt O
    2013 Tacoma
    HOT DOG!!! Good for you!! Way to keep on them!! now start thinking of other stuff you want to change while they have it all apart! Water pump etc...
    Alattaack, truchador and buzzkill911 like this.
  12. Nov 4, 2022 at 10:19 AM
    jwarr
    jwarr Well-Known Member
    Amazing how incompetent the dealers are...
  13. Nov 4, 2022 at 10:41 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Congratulations. This will be the best time to upgrade other parts that may need replacement in the future.
    You already won the lottery, do your home work, get parts at your cost, and have them installed. Make sure you ok this first with your dealer before you do this. Good luck!
  14. Nov 5, 2022 at 6:00 PM
    MikeDeason
    MikeDeason Well-Known Member
    When is the cut off date for replacement. I had the required inspection and coating. They did it properly. Thorough cleaning first.
    I was planning getting frame inspected just before the cut off for replacement
    12 years ? Is it ?
    so I can just demand an inspection just before the 12 yrs is up ?
  15. Nov 5, 2022 at 6:29 PM
    #35
    TXTaco211
    Corpus Christi, Tx
    Yes 12 years the whole csp is posted so you can read it yourself. Look for the post by MSgt O a few post up.
    TRDSport10 likes this.
  16. Nov 5, 2022 at 6:32 PM
    #36
    TXTaco211
    Corpus Christi, Tx
    That sucks but it's still better than having a holy frame. Yes inconvenience and annoyance for sure. But you essentially have a clean canvas to ensure long life.
  17. Nov 5, 2022 at 6:45 PM
    #37
    MikeDeason
    I’ve read through that thread.
    just unclear if I can call my dealer and demand a free frame inspection a month before the 12 yrs is up?
    I’ve done the inspection and coating as required.
  18. Nov 5, 2022 at 7:52 PM
    #38
    TXTaco211
    Corpus Christi, Tx
    I believe from my understanding you can ask for an inspection up to 12 years of first use. And as long as you had the crc coating performed if you live in one of the five required states by the cut off date. Which you said you did so yes you are covered for the full 12 years and can ask for inspection.
  19. Nov 6, 2022 at 2:39 AM
    #39
    MikeDeason
    Good to know. I’ll have my mechanic carefully inspect it shortly before the 12 yrs and then if anything is found I will take it to dealership.
    yea I had the required inspection and cnc and live in designated area.
  20. Nov 6, 2022 at 3:40 AM
    #40
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Congrats on the good news :)
    U need to get @MSgt O a nice fruit basket or something lol
