Another Frame Rusted
Discussion in '1st Gen. Tacomas (1995-2004)' started by curtisvitoria, May 23, 2012.
  1. May 23, 2012 at 5:46 PM
    curtisvitoria
    curtisvitoria [OP] Member
    British Columbia
    SR5 4x4
    Hey just thought I would introduce myself..... Bought a 2000 Taco 4x4 xtra cab a while back off my co-worker who bought it new. Truck is in awesome shape and was really well taken care of, I don't think he ever had it in 4x4. Long story short I recently picked up some TRD flares to put on and figured I would have my buddy cut polish it. He did a killer job and the truck looks like it got a re-spray. I figured I might as well undercoat the frame rails to finish it off. To my surprise, when I was wire brushing all of the loose crap off I noticed (more than normal) rust. I then found a couple of holes on the inner rail above the leaf spring hanger. I thought WTF? Keep in mind I had no idea about these frames or the recall until I did a search after my findings. So I call up the previous owner, and asked him about it.... He tells me after he received the letter ,he took it in and Toyota they coated the frame a sent him on his way. So after all of this I call Toyota Canada and they set up a case # and tell me to take it to the dealership, happens to be the same one who coated it. I have an appt. 930am this friday. Any guesses as to what they will do?
  2. May 23, 2012 at 5:51 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    Depends, from my readings they'll use a hammer and punch and strike the frame a few time and if a hole develops at any point they'll take further action. Whether it is buying it back/switching the frame out, I'm not sure what they'd do.
  3. May 23, 2012 at 5:55 PM
    curtisvitoria
    British Columbia
    SR5 4x4
    I just started to fall in love with this truck! Good thing I waited to order my wheels and suspension. Has anyone had the buy back after the coating process?
  4. May 23, 2012 at 7:41 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    95-00 are buy backs.
    Only 01-04 will have their frames replaced
  5. May 23, 2012 at 7:47 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    your truck is about to fail its rust test. The frame is definitely perforated! They might not even let you drive it off the lot if they deem it unsafe.
    But on the bright side Toyota Corp. should give you a hefty check in return :)
  6. May 23, 2012 at 7:51 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    99% sure you just lost your truck. My 99 Tacoma didn't even have any through holes and they bought it back last month. I had a 1999 x cab v6 4x4 240000 miles and they cut me a check for 11,500.00. The process was fast 3 weeks from inspection to check in hand.
  7. May 23, 2012 at 8:01 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    OP what did you pay for the truck and how many miles?
    With those holes, I too would guess that they won't let you drive it away. $11,500 would be awesome!
  8. May 23, 2012 at 8:05 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    strip parts off of it if they will let you and take it in
  9. May 23, 2012 at 8:05 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    Minivan
    Hasn't happened to my 99 yet from what I can tell but does anyone know if they'll still do this if the truck has a salvage title? Because I heard that they won't do anything if it does...
  10. May 23, 2012 at 10:22 PM
    curtisvitoria
    British Columbia
    SR5 4x4
    I actually got the truck for a pretty good deal, what do you suppose I strip off it? Tires? Flares? Btw the way I DID buy it from original owner like I said and he took amazing care of it. The truck (aside from the frame) is near mint. Has anyone up here in Canada been through this process? Also, how many people have gone through this after the so called re-coat of the frame? Thanks for all of the input. The truck has 165000 miles 260000 km. As far as how long I haved owned it, I actually have only had it for a month, I had big Plans for this thing and had no idea about these crap frames. I would have went newer. Even if they give me more than I paid , it's still a waste of time and a huge headache. I'm gonna research 06+ any surprises with those?
  11. May 24, 2012 at 4:33 AM
    Nick82
    Nick
    Richmond ky
    ARB winch bumper
    No they will not buy back a truck with a salvage title. Also they will let you take anything like a tool box or bed cover, however everything that is factory must be on the vehicle or they will deduct from what they give you. I was also told they will deduct for any major unrepaired damages. Otherwise they will give you 1.5 times the best kbb value.
  12. May 24, 2012 at 6:01 AM
    FishinTaco
    FishinTaco Well-Known Member
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    5100's all the way around, OME 880's and AAL, BF's 265/75R16. Switched beds from Stepside to Fleetside
    Hey Curtis, I'm in Canada and have been through both the buy back (my '98) and the re-frame on my 2002. If you love the first gens look around for one that toyota has reframed or look for one that has been checked already but hasn't failed YET but will in the near future. I did this deal and I've got a brand new 2002 taco.
    If you have any questions about the process, pm me if you want.
    Cheers and too bad that truck, looks awesome.
  13. May 24, 2012 at 6:19 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Well if you are buying in Canada the rust issue would be the same on any vehicle you buy regardless of the year or make steel when exposed to salt will rust.
  14. May 24, 2012 at 9:18 AM
    curtisvitoria
    British Columbia
    SR5 4x4
    The crazy part of all of this is where I live in Canada. We don't get many minus days throughout the winter and the city will only salt major intersections 5 times a year MAX and that is only if we have an abnormally cold winter. This thing has had mudflaps on it since day 1 and always washed. Just goes to show how vulnerable these things are to rust. I have a 1960 beetle which is 3 inches off the ground that I have driven through the winter months here and there is no rust in the pan and this thing is 62 years old.
  15. May 24, 2012 at 9:23 AM
    curtisvitoria
    British Columbia
    SR5 4x4
    Couple more pics. Also brand new Kumho 31s & windshield is 10 days old.WASTE!
  16. May 24, 2012 at 11:16 AM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    TWFSA, Here in Ontario we are the worst for rust because of our love of salt. I get my vehicles undercoated every year, I usually use Krown. They even drill holes into body parts, fill them will oil and then put a plug in, then repeat every year. Although every vehicle will rust, there are definitely lots of frames of other makes that have held up fine.
    Flake rust on the exterior of a frame is nothing to worry about (Usually). These taco frames having no corrosion inhibitor applied at Dana corp, and having the full box frame construcion that just traps rocks, sand, salt and water inside were doomed to rot from the inside out from the beggining.
    I spray oil right in my new frame every few months and after 4x4'n I blast the crap out of there with a pressure sprayer.
    I'm hoping the frame will last as long as the rest of the truck now! I think it will, but time will tell.
    DC
  17. May 24, 2012 at 11:30 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    My 95 rusted out the same place by the spring shackle. My truck was in great condition except for that and it went to the crusher. My co-worker has 2002 Tacoma and they coated his frame. The coating didn't last a year and his frame became perforated and they replaced his whole frame. Don't buy a Tacoma any older than a 2001 or you could end up in the same situation again.
  18. May 24, 2012 at 1:22 PM
    curtisvitoria
    British Columbia
    SR5 4x4
    Thanks for all the great info guys, I guess we will se what happens, I will keep you posted.
  19. May 25, 2012 at 3:15 PM
    curtisvitoria
    British Columbia
    SR5 4x4
    Well took her in @ 930am for the appointment & waited for roughly an hour and a half. When they were done the sevice mgr approached me with his card and explained that my truck (a 2000) fell one year short of the frame replacement. He then went on to tell me I would be getting an offer from Toyota for the buy back option. He said Toyota is quite generous with the offers and I won't be disappointed. He DID let me drive home and said the holes should not affect anything before this is all said and done. Waiting to hear back with an offer. I will keep you guys posted.
  20. May 25, 2012 at 3:17 PM
    2000GTacoma
    Snow Hill NC
    find out of you can strip parts off and sell them. from what i understood truck just had to drive in under its own power
