Another great Toyota care experience.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxmk8, Sep 28, 2023.
  1. Sep 28, 2023 at 1:37 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Oh geeze,
    I switched dealerships after my first experience.
    Fortunately, I had the original thin skid so it wasn't all too bad...one air dam bolt was screwed in at angle and the skid plate bolts were over torqued.
    The oil pan bolt wasn't over torqued and the plastic oil filter housing was not chipped or anything.
    The second dealership I took it to for the remaining 2yr scheduled maintenance met my needs.
    Now, I'm doing my own oil changes at the Auto Hobby Shop on Dover AFB, DE.
    Tiny_Taco, Taco_mike73 and Stevie17 like this.
  2. Sep 28, 2023 at 1:47 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    After the last two services at my dealership I looked for a local shop. Found one that does only Toyota and Lexus 3 miles from my house with decent reviews. Guess where truck is going in December when it's due again? :)
    Stevie17 and MonkeyChief like this.
  3. Sep 28, 2023 at 1:55 PM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    If you have oem thin sked plate who knows what they attempted. With the TRD skid plate there's a trap door to remove the oil filter. It is offset from the drain plug. Unless the shop (surely not a Toyota Dealership) didn't do use the little kit that allows the filter to be drained, then there would be near a quart of oil spilled on the inside of the skid plate. The one independent shop I used ONCE said they did it that way to save me money because they charge $20 to remove the skid plate. I called BS and pointed out there is a $10 kit they should have for changes on these trucks. Deer in the headlights stair followed.
    Stevie17 likes this.
  4. Sep 28, 2023 at 1:59 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Is this a Toyota OEM part? I wasn't aware of this so any info would be appreciated. I want to make sure the new shop I found uses it.
  5. Sep 28, 2023 at 2:00 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    This really isn't a big deal...
    LilTexan22 likes this.
  6. Sep 28, 2023 at 2:10 PM
    maxmk8
    maxmk8 [OP] Well-Known Member
    2022 Electric Lime M/T Taco
    Tell that to the two hours that I wasted taking it to and from the dealer. And then cleaning the truck after they “cleaned it”.
    Fuck do I know if they even torqued shit or UggA DuggA the crap out of my oil pan and plastic housing
  7. Sep 28, 2023 at 2:26 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Dealer torque wrench
  8. Sep 28, 2023 at 2:27 PM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    My several free Toyotacare oil changes have been great. Stop in on my way to work, get a cup of coffee in the well-appointed waiting room while they change oil and rotate the tires. Then they wash the truck and vacuum it for me and send me on my way. The dealer I take it to does great work. Guess it depends on your dealer. Now, of course as soon as my freebies are done I'll be buying the filter wrench thing and figuring out the few extra steps the 3rd gen takes to do it myself!
    ndoldman59 and Stevie17 like this.
  9. Sep 28, 2023 at 2:31 PM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    You know this thread is making me want to complain about how the tech's broke two of my wheel locks on different occasions and then said it wasn't their job to fix them. So i go in for Toyota care with 5 lugs and they get nervous until i re-explain they broke them on prior occasions.
    Sorry for your poor experience. Classic example of a free service barely making it free when its complete.
    Edit-bought new oem lugs to replace the broken locks and realize they somehow stripped one my studs. Going to bring this up for replacement at n/c
  10. Sep 28, 2023 at 2:53 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    :rofl: Da wife. Yes, that break away.... :cheers:
    Taco22trdor and Stevie17 like this.
  11. Sep 28, 2023 at 2:59 PM
    2022mgmtrdsport
    2022mgmtrdsport Well-Known Member
    22 TRD SPORT 4X4 DC/LB
    5% tint all around, Raptor grill lights, ProComp 17x8.5 Rockwell wheels, Maxxis 265 / 65 / 17 AT tires, TRD skid plate
    I went into Toyota for the 20K routine oil change, dropped it off. They called about 2 hours later saying its done. I walk up to my truck and notice there is a puddle of oil underneath it (I had previously removed the TRD skid plate to prevent easy access). The service adviser says oh, we'll look into it, you can wait here or come back. So I get a ride back to work and they call an hour later saying its done. They said they put it up on the rack and ran it for 15 minutes and not leaks, so it was residual oil. I had to get another ride from work back to Toyota. I drive it to work and park it. I then drive home, park it in the driveway and notice there is another puddle of oil. I drive it back down there and they pull it inside again. They come out and say they are going to replace the oil o-ring on the oil filter canister. 45 minutes later the service manager comes out and says they ran it on the rack for 10 minutes and no leaks, we'll drive it around to the front and you're good to go. I wait another 10 minutes and the manager walks out and says its leaking again. Now they are going to replace the oil filter canister. SMFH.
  12. Sep 28, 2023 at 3:12 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    oil probably just splashed onto the skid plate when draining. i don't think there is an actual leak.
  13. Sep 28, 2023 at 4:33 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Yup.
  14. Sep 28, 2023 at 5:56 PM
    Motor Away
    Motor Away Well-Known Member
    Thompson Toyota?
  15. Sep 28, 2023 at 6:01 PM
    #35
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Ehh. Ones that care won’t make this mistake.. but if you don’t put something right under the drain plug
    Like a form a funnel, once it slows to a trickle the oil runs down the pan a bit then starts leaking onto the skid plate. Lube techs suck for this.. and I get stuck cleaning up their messes
  16. Sep 28, 2023 at 7:04 PM
    #36
    maxmk8
    Wow
  17. Sep 28, 2023 at 7:38 PM
    #37
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    You pay a premium for them to do the job correctly and get this instead . This is why I do most of my work myself to avoid stuff like this . Hopefully they didn’t over tighten things in the process or leave the cap off . I have read others have that happen to them .
  18. Sep 28, 2023 at 9:07 PM
    #38
    maxmk8
    I did the break in oil change and one at 5k miles myself. The truck was at 8600 miles and 12 months so I figured I’d get it out of the way for the freebie.
  19. Sep 28, 2023 at 9:21 PM
    #39
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Like a mini-vacation.
    Canadian Caber likes this.
  20. Sep 29, 2023 at 2:36 AM
    #40
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    ANY semi educated mechanic (especially one that works at a toyota stealership and sells tacomas with front skid plates) should know about the oil pooling there.
    Oh wait!! I said semi educated...
    Oil rats are typically the lowest person on the ladder thus usually lacking any skill at all.
