ANOTHER ground question
Discussion in 'Audio & Video' started by HitTheBid, Jan 2, 2011.
  1. Jan 2, 2011 at 4:41 PM
    HitTheBid
    HitTheBid [OP] Member
    Jess
    NorCal
    08 Double Cab LB TRD Sport 4x4
    Tint, Navi & 6 speakers
    I searched through several forums and am not sure I have heard anyone address or question the issue I am having.
    I am getting a loud hum upon starting my truck that gradually fades within 30 seconds. The sound is louder the colder it is outside. The hum is only present with my door speakers and not my powered sub. The amp running all my door speakers has an 8 gauge power and ground wire.
    The ground is connected under a rear seatbelt bolt. Paint taken down to bare metal. I spent the weekend trying different ground spots with zero luck.
    Help!
  2. Jan 2, 2011 at 4:49 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Ground wire should be very short, if your rca cables are anywhere near your power wires than this is probably your problem. If your rca's are run with your power wires than it's definitely your problem.
  3. Jan 2, 2011 at 4:49 PM
    HitTheBid
    Jess
    NorCal
    Ground is about 1-2 feet from amp tops!
    I did try sanding out a patch about 2" in diameter surrounding the ground spot. No luck. Where is your amp and ground spot?
  4. Jan 2, 2011 at 5:04 PM
    Johns Taco
    Albuquerque, NM
    I have 3 amps and they are all grounded directly to the frame, the way you have your amp grounded should be ok. I would look to make sure your rca's are not near a 12v power source, make sure you also use an adapter plug to hook up you deck to the factory wire harness. How old is your amp?
  5. Jan 2, 2011 at 5:33 PM
    HitTheBid
    Jess
    NorCal
    Thanks everyone. I don't remember where the 12v is wired in relation to the rca's. I am going to check that stat!
  6. Jan 2, 2011 at 8:43 PM
    HitTheBid
    Jess
    NorCal
    The amp is 3 years old and the problem has been there since the day I initially installed it.....yes, 3 years ago. :eek:
    I am using an adapter plug for the wiring of the HU. I definitely need to check the wiring of the 12v and rca's.
  7. Jan 3, 2011 at 8:39 PM
    silvr07taco
    silvr07taco Well-Known Member
    SoCal
    07 prerunner Access Cab
    K&N air filter, Dual XDMA6415, Sound Ordnance™ M-1350, Infinity 1252w, Custom 12" sub box.
    adapter plug?
  8. Jan 3, 2011 at 8:42 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    ground to frame and look into grounding kits to help with power surges u might run into. ebay and best buy sell them
  9. Jan 3, 2011 at 9:14 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    could be your air conditioner?
  10. Jan 3, 2011 at 9:47 PM
    HitTheBid
    Jess
    NorCal
    Mispoke....The wiring harness.
  11. Jan 4, 2011 at 6:21 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    A low hum that fades after the car is started? That doesn't sound like a ground problem at all. A ground problem will usually sound like a high pitched whine that increases with RPM and electricity use (AC, windows, headlights).
    I'd say it's a problem with the amp. You stated it was there since you installed it 3 years ago. What amp is it?
  12. Jan 4, 2011 at 6:22 AM
    ItalynStylion
    Steven
    DFW, Tx.
    And why after 3 years are you just now figuring it out lol?
  13. Jan 4, 2011 at 6:32 AM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    Are you using a LOC with the stock headunit?
