Another guess the noise thread
Discussion in 'Technical Chat' started by Superhulk LB, Feb 7, 2023.
  1. Feb 7, 2023 at 7:50 AM
    Superhulk LB
    Superhulk LB [OP] Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Before I pull the serpentine belt off. Anyone experience this noise and know if it is likely the belt or a pulley? Doesn’t really show up when at idle, but gets awful once you accelerate.
    https://youtu.be/6SQHbci6aRg
  2. Feb 7, 2023 at 10:48 AM
    MR5X5
    MR5X5 Well-Known Member
    My vote is a bad pulley bearing.
    Pull the belt and spin the pulleys by hand. You'll be able to feel that one.
    Superhulk LB[OP] likes this.
  3. Feb 7, 2023 at 12:15 PM
    Superhulk LB
    Josh
    Oregon
    thanks. I’m guessing I could even just remove enough tension on the belt to spin the pulleys by hand. Thanks for the idea!
  4. Feb 9, 2023 at 5:51 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Here's a good video on how to change your serpentine belt. (For V6 4.0L 2nd gen -- if you have a different engine, look for a different video. But the basics are the same: you can relieve tension on the belt via the tensioner pulley, and that will allow you to spin other pulleys by hand & possibly locate a bad one. (If it's a pulley..)
    https://www.youtube.com/watch?v=ZKq3FBsvFsI
  5. Feb 9, 2023 at 6:37 PM
    Superhulk LB
    Josh
    Oregon
    Of course the squeal stopped again yesterday after I decided to spend time trying to figure out the cause.
    Next time it squeals I’m removing the belt and spinning pulleys.
