Another Ham Radio Install
Discussion in 'Audio & Video' started by SargeBSA, Apr 13, 2015.
  1. Apr 13, 2015 at 7:37 AM
    SargeBSA
    SargeBSA [OP] With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    Quite an easy install.
    - TYT 9000D
    - 18ft TruckSpec Mini Coax Cable
    - Heavy Duty Antenna Stud Mount
    - 4ft Firestik II
    - 4ft 12 Gauge Wire With Ring Wire Connectors
    - 2 inch of 90 Degree Angled Hole Steel
    1: If installing in front center console the back will need to be cut out for best fitment.
    2: Run the coax under the front driver side carpet to the plastic plate covering the wiring next to the door, then under the rear driver side carpet to the first grommet no need to remove the seats as it is easily reached by barely pulling up the carpet. After the grommet run the coax in the frame rail to protect it. I ran mine up behind the cab and over the front bed rail but you could run up through the bed rail.
    3: For mounting the Antenna see pict it explains more far better than I can.
    4: Since you will need a ground plane attach a wire with ring wire connectors on each end one side to the antenna stud mount and the other to the frame rail I found a bolt holding the bracket for the brake line to be the best spot.
    5: Back in the cab attach your power wires to the back of the device and run the cable through the back of the front center console and under the carpet behind the peddles to the firewall boot( I had to cut the wire since mine came pre fused if yours is not you will need to add a fuse no bigger than 10 amps) I used to clothes hanger method another member suggested to pull the wire through the firewall boot.
    6: I directly attached the positive and negative wires directly to battery to cut down on any electrical noise that could come from the engine.
    7: On manual transmission trucks the front center console is very small so I did not attach any mounts a benefit is its such a squeeze that once in it does not move. Also if antenna is going to be mounted permanently than I recommend loctite on the stud as it has a tendency to come un done on rough trails or long distance travel. With the coax cable for added protection under the truck I added a corrugated plastic tube over it.
    brockefellar likes this.
  2. Apr 13, 2015 at 7:37 AM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    Will add more pictures later.
  3. Apr 14, 2015 at 12:41 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    How tall is the radio? Short enough to fit in persay... a single-din compartment?
  4. Apr 14, 2015 at 12:48 PM
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    cool set up did you fuse the negative as well?
  5. Apr 15, 2015 at 1:54 AM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    How are those radios in general, quality?
  6. Apr 15, 2015 at 8:11 AM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    So far so good, only had for a few weeks. All the online chatter and reviews say this is the best radio for your monies.
  7. Apr 15, 2015 at 8:12 AM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    The radio came with the power cables double fused on positive wire and single fused on negative wire.
  8. Apr 15, 2015 at 10:23 AM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    Most hams are going to a tight squeeze with this it's not really the height or width but length at almost over 10 inches some cutting a drilling might be necessary.:D
  9. Apr 16, 2015 at 9:46 AM
    Ihatetacomas
    Dylan
    Elko NV
    Good to know :D thanks for the info
  10. Apr 30, 2015 at 5:59 PM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    Decided to ditch lame rednick antenna mount and paid a whopping 10 bucks for this mount at the local truck stop. By the way this mounting position I found I do not need a grounding wire.
  11. Apr 30, 2015 at 6:38 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites, BD Fogs
    I'm curious about the firestik antenna as they don't list a 1.25m antenna.
    Also, how much activity do you see on that band. Here in PHX it's not dead, but it's not very active. 2m is by far the hot with 70 on its tail
  12. May 1, 2015 at 7:01 AM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    The antenna is a firestik II every ham owner I talked to said it would not work but so far its picked put Raleigh frequencies in Boone(200 miles as the crow flies)
    Around here its pretty dead, other than Fire/EMS frequency most HAM operators tune into repeaters and have weekly group sessions(they are really boring) but other than that, its dead.
  13. May 1, 2015 at 7:09 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Cool I was looking into a Yaesu FTM 400 dr just haven't pulled the trigger yet and I need to take the test my studying has fallen off due to work
  14. May 4, 2015 at 12:56 PM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    I feel y
    I feel ya, I not had time to take the test. Life has been way to busy might be fall before I can take it.
  15. May 4, 2015 at 1:31 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Ok, yeah.... you might hear people but your SWR will be through the roof when you transmit. you need to buy a proper ham antenna made for 220mhz. If you need help with any of this, hit me up. I'm in Apex and Been a ham for 20+ years. Also an electronics engineer.
  16. May 4, 2015 at 1:37 PM
    boatbuilder
    boatbuilder Well-Known Member
    Jim
    Tonasket, WA
    12 regular cab 4 cyl 4wd
    A lot!
    I'm holding out for a removable face 2m. I know, I'll be dead first.
  17. May 4, 2015 at 1:37 PM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    I hate to discredit your 20 years of ham experience but last week I had my antenna tuned by Racing Radios in Mooresville and everything is fine, SWR is at a level I can live with, though not perfect but it does work and transmissions come in clear as bell.
    Eh who knows made its the radio making me look or just dumb luck. Should get together sometime go wheeling.
  18. May 4, 2015 at 1:39 PM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    While looking for mine I found a couple of the removable face ones on the interweb but they were expensive as in over $400. When they come down on price I might be up grading.
  19. May 4, 2015 at 1:47 PM
    PreRunnerSeth
    Apex, NC
    Usually Antennas are made to be full, half or 1/4 of the wavelength. seems that a 1/4 wave 11m CB antenna is almost exactly double the wavelength of 220mhz. I'm researching the use of double wavelength antennas. I have never heard of anyone making a double wavelength antenna. its entirely possible that it works.
  20. May 6, 2015 at 11:46 PM
    boatbuilder
    Jim
    Tonasket, WA
    A lot!
    Ya, like all multifreq radios it should be about $20 for the patch cable but alas it's "different" so lets charge a bundle. I'm waiting too
