Another leaking headgasket (2006): new engine or bail?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Katha, Feb 3, 2021.
  1. Feb 4, 2021 at 5:55 AM
    #41
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    With a job as big as head gasket replacement on these engines, be very careful if you choose to get it repaired. How many other Toyota head gasket repairs did any independent shop you may take it to do? If you look at the job on You Tube you can see it is not a shade tree mechanic thing.
    I suspect a well seasoned mechanic could do it without any mistakes with maybe only one or two bolts left over, but from what I have seen, it is a good idea to replace a bunch of other things while in there too. The timing chain, water pump and maybe the valve stem seals.
    I too have an 05 with 130K on it. I have taken good care of it, but am in wait for the big one and if it happens, I will probably try some Steel Seal head gasket repair. I was told it is not compatible with Toyota coolant so the system would be flushed first and pure water added before putting in the Steel Seal.
    If that did the trick and cleared the problem, it may be time to start looking for another ride. If not, back to square one.
    Katha[OP] likes this.
  2. Feb 4, 2021 at 7:08 AM
    #42
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    An engine with the least miles you can afford. You will have to trust the guy selling you a used engine or rebuilding the top end of your engine. And how much you want to spend are decisions only you can make.
    The older the truck gets, the more maintenance it will need. That won't change.
    MtnMan307 and Katha[QUOTED][OP] like this.
  3. Feb 4, 2021 at 4:16 PM
    #43
    beaudeen
    beaudeen Active Member
    Ontario, Canada
    2005 trd off road
    Just the other day, I requested a quote on a 2005 4.0 engine swap. SAM Auto in Toronto. Although he didn't have a replacement engine at the time, he said if I supply the engine along with oil/filter and coolant, his fee is $1300 CDN for the job.
    Although mine currently runs totally fine at 374k KM (225 mi) knock on wood
    Ya never know.
    Rsmallw2 and Katha[OP] like this.
  4. Feb 4, 2021 at 5:26 PM
    #44
    Katha
    Katha [OP] Active Member
    Good luck to you! I don't dare drive my truck very far at all.
  5. Feb 5, 2021 at 1:24 PM
    #45
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    OP, where are you located? Maybe we can help source out a used engine for you.
  6. Feb 5, 2021 at 1:47 PM
    #46
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    So a '12 and up 4.0 engine will work in an '06 truck as long as the original exhaust manifolds are used ?
  7. Feb 5, 2021 at 8:25 PM
    #47
    Stiffy62
    Stiffy62 From the Frame up.
    Southern Indiana
    09 Tacoma,Access Cab,Base(not any more)
    You been here to long, When there's TOO MUCH TO LIST!
    I'm about halfway thru his build thred, I would "JUMP" all over the offer in post #2. .....But Allas ...he jest.
  8. Feb 6, 2021 at 7:00 AM
    #48
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    50hrs for an engine swap... from a "dealer" hahahahahahahahaha. Fuckin' crooks.
    Rsmallw2 likes this.
  9. Feb 6, 2021 at 9:36 AM
    #49
    Katha
    Well, it never rains but it pours. I've just had a death in the family (my brother) as of last night, so this will have to be put on hold for at least a week. I want to thank you all for your replies and helpful suggestions. We 99% at this point have decided to mix whatever trade-in/sale, savings and loans we can cobble together to get another truck, which will bring its own challenges. It just seems too complicated trying to figure out a used engine that will work and somebody to put it in and do the other things that really should be done and be able to trust that everything will be done right for such an old vehicle. There are other things that will likely need attention in the near future. A friend who's a retired mechanic said we can probably expect something else major to go within 30-40k miles, so we're not sure it's worth it to continue with this truck. It's hard making this decision, and now with a looming funeral, the stress level is even higher than it was. So taking a break from stressing about this for the time being. Be well, all, and I'll be back later on. And will probably pick your brain on what to buy. Prices are so high right now that it's very scary to go into a large debt hole without sufficient resources to handle it should something major occur in a *newer* truck. Thank you all.
  10. Feb 6, 2021 at 9:39 AM
    #50
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Wish you the best OP, sorry for your loss, this truck business will work itself out. Take care of yourself and family.
    specter208 likes this.
  11. Feb 6, 2021 at 9:39 AM
    #51
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    My condolences.
    Forget about the truck. Take care of family first.
    In the long run, I believe you are making the wise decision about the truck.
  12. Feb 6, 2021 at 9:45 AM
    #52
    Katha
    Thank you
  13. Feb 6, 2021 at 11:40 AM
    #53
    GorgeRunner
    2005 PreRunner
    In the long run, it's just another thing. I think most knowledgeable Tacoma owners would say you got your money's worth, that's all you can really ask for. You'll find another truck. Start saving your pennies and take care of business. Good luck.
  14. Feb 9, 2021 at 3:50 AM
    #54
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    sorry for your loss. I hope all things work out for you. Lots of fine folks on here
    willing to help and lend a hand anytime. Best of luck.
  15. Apr 10, 2021 at 4:39 PM
    #55
    Katha
    Hello again all. Well, just wanted to update you. After everything finally settled down and life returned to "somewhat" normal, we found a new local mechanic with 35 years experience who has great reviews, and we got a quote from him on replacing the head gasket. The truck never overheated, and there were no problems with the engine, so while the engine was out, we also had him replace the water pump, the timing chain, the rear main seal, serpentine belt, coolant hoses, etc. and do an oil change. Our last stimulus check paid for most of it, so we are grateful for that. With a new frame put on under recall a couple years ago, we practically have a "new" truck. We really love our Taco and hated the thought of letting it go, even with as many miles as it has. We are going to fix some other things that need attention, like a dented tailgate and rear quarter panel, which insurance should cover minus the deductible. And some things like busted console latch, broken cup holder and new floor mats and mud flaps. Of course, if something major like the transmission goes, it would still be cheaper to replace that than to buy a newer used Taco with the way prices are today, and we would know what we're getting. Better the devil you know.... Again I want to thank everyone for your input and help while we tried to figure this out. Really appreciate this group and YOU!
  16. Apr 10, 2021 at 6:27 PM
    #56
    TacoTuesday1
    SD CA
    maybe if the mechanic chugged a pint of lean
  17. Apr 10, 2021 at 6:40 PM
    #57
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Um, do this op.
  18. Apr 11, 2021 at 1:01 PM
    #58
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Give 'em some meth instead and he can probably get it done in under twelve. :bananadead:
  19. Apr 11, 2021 at 1:20 PM
    #59
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the dealer cost is extremely H I G H for new/used engines..............
    U have gotten the best out of Ur $$$$$$ spent
    find a shop that will do a new engine for less............
  20. Apr 11, 2021 at 1:22 PM
    #60
    Rsmallw2
    Rsmallw2 Well-Known Member
    Michigan
    06 Tacoma PreRunner V6
    Dude, if you got 320K out of any vehicle, you made out like a bandit.
    MtnMan307 likes this.
