Another lean question and installing OME
Discussion in 'Suspension' started by Imageoguy, Dec 11, 2012.
  1. Dec 11, 2012 at 8:29 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Well, got a couple hours to start installing my OME + Dakar + LR UCA today. While doing my measurements before starting, I noticed that I didn't have the infamous Taco lean I've got 20 1/4'' from center of wheel to fender for both sides in front and 22 1/8 on both side on the back. The bed is empty and a bit more than half a tank of gas.(2012 DCAB LB).
    Is the Taco lean something that develops?
    Should I still add a trim packer on the driver's side?
    BTW, I also measured the angle of the driveshaft, rear is 4.30 and front is 5.00 deg. Will report back once the install is complete in a few days.
  2. Dec 17, 2012 at 5:58 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Taco lean is corrected with stock springs by having a longer one on the driver side.
    Aftermarket springs are the same length so you need to add the trim packer (for OME) or a spacer for others to compensate & maintain level.
  3. Dec 17, 2012 at 6:49 PM
    Imageoguy
    2012 DCLB SR5
    Thanks. Took a chance and installed it last weekend. Good thing I did, it's sitting straight with the lift kit.
  4. Dec 17, 2012 at 7:08 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    I had the lean on my stock set up, with my 5100's @ 2.5" (stock springs) and now with my 5100's @0 and my 885's
  5. Dec 18, 2012 at 7:27 AM
    4Wheelin4Banger
    Randy
    I'm nice & even with my 885s on Nitro Sports with a trim packer.
  6. Dec 18, 2012 at 7:33 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Same here
  7. Dec 18, 2012 at 10:32 AM
    Bookin
    Bookin Well-Known Member
    Sorry to thread jack, do you any of you have pics of the shock/spring assembled to show the placement of the trim packer?
  8. Dec 18, 2012 at 12:31 PM
    4Wheelin4Banger
    Randy
    I don't have a pic but it goes on the bottom spring perch between the spring perch & coil on the driver side shock.
  9. Dec 19, 2012 at 1:54 PM
    Bookin
    10-4. Thanks bud.
