Another LED Bed Light Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Critical B, Sep 10, 2013.
  1. May 7, 2014 at 7:14 AM
    #41
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Nicely done. Note to all, any wire you solder must be kept free of movement and vibration or they can crack. Any crimp connections that may get wet can be done with marine crimp connectors, they have built in shrinks with sealant in them that is heat activated. I go one extra step and put a dab of dielectric grease on the end of the wire before inserting; should be good for life.
  2. Jul 8, 2014 at 7:04 PM
    #42
    coastalreb
    coastalreb Well-Known Member
    Mississippi Gulf Coast
    2012 TRD Sport
    sub'd.
    also... Hotty Toddy OP!
  3. Jul 16, 2014 at 12:52 PM
    #43
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    After some more research on these 5 meter strip LED lights like the OP has I see there are some variations.
    - 3528 LED's (3.5mm x 2.8mm) and 5050 LED's (5.0mm x 5.0mm). With the 5050 you get more lumens, more brightness per LED.
    - Warm White vs. Cool White. Warm white are more toward the yellowish light, Cool white more bluish. So Cool would be a more halogen-like bright light, Warm more mellow, softer.
    - LED's per meter vary. If you want the most light no matter the color, you buy a 5050 LED strip with 60 LED's per meter.
    This E-bay vendor gives you choices http://www.ebay.com/itm/5m-3528-505...ght-DC-12V-new-/201106934886?var=500280492740 about color, density.
    #43
  4. Jul 29, 2014 at 7:01 PM
    #44
    coastalreb
    2012 TRD Sport
    Can someone tell me what fuse I need to run this to the fuse box?
    I have the LED strip, the connectors, a switch, and some 16 gauge wire. I don't know what type or specific fuse to get because I have zero electrical knowledge. I don't know how to wire this thing up but dammit I'm going to figure it out because God gave us the internet
  5. Jul 30, 2014 at 5:37 AM
    #45
    Critical B
    Critical B [OP] Member
    Cleveland, OH
    2013 PreRunner TSS Double Cab 4-Cyl
    Fog Lights, Auto-Tailgate Lock, White LED Interior Lights
    Okay, engineers on here are gonna laugh me out of the forums when they see it, but I'm posting a "wiring diagram" below. For the fuse, I used 10A fuses and an Add-A-Fuse I picked up at Autozone (in the fuse section) for about $1 or $2. See the pics at the start of the thread to see where (generally) i plugged it in. I recommend connecting the add-a-fuse directly to your LED strip to test it before wiring everything in permanently. Alternatively, you could test with a small leftover strip of LEDs. Oh, and if you're going to be disconnecting your battery, go ahead and pull the fuse for your horn. (actually, you can use pull that fuse and use that socket for testing since it's always on.)
  6. Jul 30, 2014 at 8:05 AM
    #46
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    On my bed light circuit, I hooked up the light to the dome light circuit so I am using the same fuse as the dome light. I did change my dome light to LED so there is no current overload. I did not have to buy a fuse, add a fuse (the price of which I think is ridiculously high at the time I was looking for one) or a switch.
    http://www.tacomaworld.com/forum/li...ome-light-circuit-lots-pics-wire-routing.html
    right,the answers are out there, no need to pay someone for the same information. and there are plenty other people who will help without asking for money. :)
  7. Jul 30, 2014 at 9:03 AM
    #47
    coastalreb
    2012 TRD Sport
    Thanks for the info, both of you! I'm out of town this weekend, but will post pics when I finish the project. Hoping to tackle it Sunday.
    Also, with my left over wire and LED lighting, I'm going to use a reed switch to make an LED strip light up on the inside of my Yeti cooler when it opens. I'll post pics if it works.
  8. Oct 13, 2014 at 8:29 PM
    #48
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    bumping this back up for a reference... Just ordered LED strips
  9. Oct 14, 2014 at 8:09 AM
    #49
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    I just added this to my truck and its awesome. There are two PITA's ive found so far though.
    1. the connectors that join the LED light strips after you cut them really suck. they make contact on the LED strip on these tiny little contact points. So if they shift or loosen, the lights dont work. Then you have to unroll your bed cover (if you have one) and tap and shake the connection till it works again. I thought i read about someone soldering these, but i think that would be pretty tough to do, the connections are so small. Maybe i just suck as soldering.
    2. The strips i bought didnt stick to the rails 100% so i am thinking down the road theyll start to peel off again and ill be super gluing them back on. Just not the quality i try to bring to my truck... And yes i cleaned the rails well and installed them in warm weather, if anyone is wondering.
    Overall this is the best way to have lights though! Super useful, 100% hidden, and the magnet switch rocks so they turn on automatically.
    OH AND ONE OTHER THING. I wired a toggle switch in just before the magnet switch so if i want to manually turn them off i can do that. I put the switch in the metal housing area of the tail light, facing forward toward the cab so you dont see it. Nice to have the option of turning the lights off if you choose....
  10. Oct 14, 2014 at 8:21 AM
    #50
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    1. They're made to be soldered. It's relatively simple.
    2. What did you use to clean before adhering?
  11. Dec 19, 2014 at 8:04 PM
    #51
    Liem Salim
    Liem Salim Active Member
    Bremerton, WA
    2013 Tacoma TRD Sport
    K&N Cold Air Intake (63-Series) Retrofitted Headlights (FX-R Stage III w/ Apollo 3.0 shroud) Leer 180 Cap Custom Bed Sliders iPad Mini Entertainment System LED bed lights
    Did you use a Relay?
  12. Dec 19, 2014 at 8:24 PM
    #52
    steveo27
    Pittsburgh
    No need for a relay. just run a fused wire from what ever you plan on using as the 12v source
  13. Dec 20, 2014 at 4:05 PM
    #53
    Liem Salim
    Bremerton, WA
    This is my diagram but in stead of a in line fuse have an add a fuse and piggy back off on a always hot fuse. I have 2 switches. 1 for manual on off and the other magnetic for the tail gate. What do you guys think!
  14. Jul 12, 2015 at 7:24 AM
    #54
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Sub'd love the diagrams!
  15. Aug 27, 2015 at 1:48 PM
    #55
    Liem Salim
    Bremerton, WA
    So I have had the bed lights in now for a couple of months now and only one thing I would do differently is get rid of the quick clamps that are used in the corners and just use a wire soldered to each LED stip. The clamps would come loose and there were not that reliable on staying connected.
  16. Aug 27, 2015 at 2:15 PM
    #56
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I put mine in as one whole strip to avoid cutting and soldering and turned out great. Ran wire under the fuse box and put a switch in one of those useless cubbie holes that way I can put the lid on to protect/ hide it.
  17. Mar 25, 2018 at 11:57 AM
    #57
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Did anybody ever try using the 7 way trailer hitch for +12V for their bed lights? Trying not to run the wiring all the way up front.
