another lift question ..
Discussion in '1st Gen. Tacomas (1995-2004)' started by radcat692000, Jan 21, 2012.
  1. Jan 21, 2012 at 6:41 PM
    radcat692000
    radcat692000 [OP] Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    i'm planning on a 3" lift( bilstein/eibach).... question,,,do i need extended brake lines for the rear,,,i'm doing an aal..... if so,,,do i need 1 or 2?? plus with the front bilsteins,,,,which setting on the shock is 0??? i see the 3 settings,,but not sure which way they are considering to be 0??
  2. Jan 21, 2012 at 6:44 PM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    I put a 3" lift on mine...as long as I don't do serious off road rock crawling I've been told I'm okay without the brake lines....from Toytec....
  3. Jan 21, 2012 at 6:46 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    I got the extended brake lines for the peace of mind. On the bilsteins, the lowest notch on the shock would be 0".
  4. Jan 21, 2012 at 8:15 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    The need for extended brake lines seems to vary by vehicle. Some folks report no need for one with 3"+ of lift. Others (like me) needed them with only ~2.5" of lift though, admittedly, mine was required to accomodate full drop/extension of my new leaf springs. ttran summed it up nicely... Extended lines give you "peace of mind". Moreover, at about $100 for a complete set of Goodridge braided stainless lines, they're cheap insurance that provides the added benefit of improved pedal feel. Bottom line: Highly recommended!
    Stock setting on 5100s is the lowest (or 0) notch. The others provide 1.25" and 2.5" of lift, respectively, on 1st Gen Tacomas. When paired with the Eibach springs you're getting, they should be left at stock/0. Their pre-loading functionality is designed for lower spring rates than the Eibachs provide (e.g., stock springs).
  5. Jan 21, 2012 at 8:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You don't need new front ones. Its not necessary at all.
    Id get a rear one(you only need one) Just to be safe. But i ran my 96 taco with 4''+ of rear lift on stock hose for a while I never wheeled with it like that tho and put a longer one on before i went wheeling.
    The bottom setting is what you need to set it on
    And i know your new..but the search function is your friend! This has been covered a MILLION times.
  6. Jan 21, 2012 at 8:40 PM
    Norton
    Like I said, opinions vary. FWIW, however, my Goodridge lines came with a manufacturer recommendation against mixing stainless and rubber brake lines. Whether that's pure propaganda or not, you definitely won't get the full benefits of increased durability and improved pedal feel unless you upgrade all three lines to stainless.
    Great advice since, according to Google, there are over 95K 5100-related hits here on TW! :thumbsup:
  7. Jan 21, 2012 at 9:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh, i haven't noticed a difference. Only thing that made a huge difference was a lift bracket for the BPV
  8. Jan 21, 2012 at 9:32 PM
    Norton
    I suppose that's another "opinions vary" thing. I noticed a huge difference in brake feel and responsiveness when I upgraded (all three lines) to stainless. My B.A.M.F BPV bracket was already in-place. :cool:
  9. Jan 21, 2012 at 9:35 PM
    Sunner
    Sunner Well-Known Member
    For less than a $100 investment, better safe than sorry.
  10. Jan 22, 2012 at 7:08 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    the problem is ...even with the search function you can search for hours and still not find a specific answer to a question...hell even the sticky on faq's about lifts never even covers extended brake lines or the use of shims..... a proper sticky should cover everything from a to b concerning a lift,,,not what you can get by with but everything you may encounter..i have searched trust me....
