another lift question
Discussion in 'Suspension' started by basktaco, Dec 12, 2008.
  1. Dec 12, 2008 at 12:13 PM
    basktaco
    basktaco [OP] Well-Known Member
    Bliss, Idaho.
    2012 SR5 DCLB
    duratracs/ultra phantom wheels/plasti derped all the chrome
    hey guys i was lookin at the toytech site and cant decide which is better: this one[​IMG]
    FRONT: (2) OME 884 standard/light load front lift coil springs. Also includes ToyTec Top plate spacers for a full 3" front lift & (6) top plate studs.
    REAR: (2) 2" lift ToyTec Add-a-leafs by Alcan spring (a long add-a-leaf for the best ride), w/OEM style anti-friction Pads, & new leaf spring center pins.
    or this one
    FRONT: 3" Front Lift Spacer Kit-- CNC Machined From 6061 T-6 Aluminum (Available with Black anodized finish for $20.00 additional -TAC3B-05-AL). 6 longer top plate spacer bolts.
    REAR: 2" lift ToyTec Rear Add-A-Leafs made by Alcan Spring-- With OEM Style anti-friction Pads, these are a long add-a-leaf for the best ride. New Leaf Spring Center Pins.
    they aslo have heavier duty spring kit available.
  2. Dec 12, 2008 at 3:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Replacement springs will be much better than spacers.
  3. Dec 12, 2008 at 3:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    +1 on the springs, will give you a better ride than the coil spacers.
  4. Dec 12, 2008 at 4:31 PM
    basktaco
    Bliss, Idaho.
    2012 SR5 DCLB
    cool thanks guys
  5. Dec 12, 2008 at 4:37 PM
    Flaadog
    Flaadog Well-Known Member
    Pacifica, CA
    2002 Double Cab TRD SR5 4x4
    Toytec 3" Pro Deluxe 1000 lift, Bedrug, Snugtop, Yakima rack, Goodyear Wrangler Silent Armor 265/75R16
    I went with option 2 and it is definitely a more harsh ride. I would love to know what the new coils feel like, but.... Anyway, regardless of the rough ride, it has helped big time off road.
  6. Dec 13, 2008 at 5:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Any time a lift is being installed, and the spring rates are being altered, new shocks are in order. The OEM TRD Bilstiens are only valved for the stock spring rate, and are not up to the task of dampening preloaded springs, or springs of a higher rate. For a better ride, consder swapping out to the 5100's. OME shocks have a spring rate that is matched to their springs, and the Tacoma.
  7. Dec 13, 2008 at 5:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Dec 13, 2008 at 10:33 AM
    basktaco
    Bliss, Idaho.
    2012 SR5 DCLB
    will the 5100s work with the 885s?
  9. Dec 13, 2008 at 11:10 AM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    Of course they will, anything will "work". Here is my advise: Save your money and do it right the first time.
    I'd would go with the first kit (OME coils) and some OME struts up front. That combination would match best.
