Another lift question:
Discussion in 'Suspension' started by IndigoTaco, Sep 26, 2009.
  1. Sep 26, 2009 at 1:02 PM
    IndigoTaco
    IndigoTaco [OP] Well-Known Member
    07 Access Cab Sport 4x4
    I'm looking to level off my truck a bit, but keep some rake for when I tow. (I don't want it to look like it did before the TSB)
    I want to have good alignment, and keep as close to the factory ride as possible (being my daily driver 24 miles to work one way). I've ready too many posts from guys having issues with the 5100's set at 2.5 and 1.75, even some at .85 to want to go that route.
    Keeping a small budget, here's what I am thinking of, please let me know if I'm off at all, or if you have a better solution.
    OME 883's with 5100's at all four corners, fronts set at '0'. Right now, my truck sits at 35.5" for both front wheel wells (NO LEAN!), and 37.75" for the rears, after the TSB. I figure the new leaf pack is as settled as it's going to get after hauling dirt, mulch, etc as well as towing my boat all summer. I'm going to go up to BFG A/T in 265/70/17 before winter, and will do all of this at one time. Anybody running this? Any suggestions? Thanks
  2. Sep 26, 2009 at 4:33 PM
    IndigoTaco
    I know someone has to have an opinion!
  3. Sep 26, 2009 at 6:30 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yeah, sounds good. you can use your stock coilsprings if you want to save a few bucks. but the OME's will ride better.
  4. Sep 30, 2009 at 9:02 AM
    IndigoTaco
  5. Sep 30, 2009 at 9:21 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    whats the bump for? what else you want to know?
  6. Sep 30, 2009 at 10:45 AM
    IndigoTaco
    If anyone runs this setup, or has experience w/ the 883's. Everything I read is for 884's and 885's.
  7. Sep 30, 2009 at 11:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What kind of truck do you have? Quad cab? Ext. cab?
  8. Sep 30, 2009 at 2:00 PM
    IndigoTaco
    07 Access cab, 6cyl 6sp. I'd like to keep some rake, that's why I'm interested in the 883's as opposed to the 884's.
