Another lift question
Discussion in 'Suspension' started by gopens48, Jun 9, 2010.
  1. Jun 9, 2010 at 8:54 AM
    gopens48
    gopens48 [OP] Well-Known Member
    Utah
    06 SR5
    Alright so i have decided to go with Leeper 2.5 coilovers up front, and most likely toytech AAL's in the back. I will also be getting a diff. drop kit to throw on. Is there anything else you guys would recommend that I get as far as suspension goes? I only really do light off roading, not much other than getting to camping/fishing/hunting sites.
  2. Jun 9, 2010 at 9:10 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Longer rear shocks to match the rear lift?
  3. Jun 9, 2010 at 9:37 AM
    gopens48
    Utah
    06 SR5
    are you suggesting new shocks along with the AAL? or in place of the AAL? If i got rear bilstein 5100's, would that eliminate the need for an AAL or would i still need it?
  4. Jun 9, 2010 at 10:41 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The AAL is what gives lift. The shocks are what control the motion of the vehicle. Since you are making the rear end taller. Your rear shocks will be extended more. Since this doesn't leave a lot of down travel left with the stock shocks, sometimes people can feel the shocks top out. A new set of 5100s are longer than stock for lifted applications.
