Another LIFT thread
Discussion in 'Suspension' started by jarpil, Nov 7, 2011.
  1. Nov 7, 2011 at 6:46 PM
    jarpil
    jarpil [OP] Well-Known Member
    Kalaheo, HI
    2017 Tacoma TRD OR DCSB, black
    I am sorry for starting another thread like this but after going through all the lift threads on this forum for two days i am confused the same i was before i began reading.
    I am thinking about 2-3" lift with 285's Mickey Thompson Baja ATZ tires with 16" wheels. If i do that i want to do it right and have no issues with tire wearing etc.
    I was told in our local shop that new rear shocks would be needed as the stock Billsteins wouldn't work. Front shocks would work according to the local shop guy. I was thinking about set of Billstein 5100's for all 4 corners and then i don't know...
    Do i need spacers? Do i need to do any trimming? I would appreciate greatly a help in this as i am really confused.
    Would Revtek 3" lift http://www.revtek.com/toyotasusp.asp#426 work with stock shocks?
  2. Nov 7, 2011 at 11:11 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Nooooo! Revtek is the last thing you want! If you're looking for 2-3" out of those get some eibach coils too! With the 5100's set at .85" you'll have 2-2.5".......or toytec already sells a set for $599 and you can replace them yourself with basic hand tools, no spring compressor needed!
  3. Nov 8, 2011 at 7:17 AM
    jarpil
    Kalaheo, HI
    Ok no spacers then. I am leaning towards 5100's with Eibachs and Toytec AAL(do i need AAL with my suspension TSB?). Should I get 5100's for all 4 corners or just the front and keep stock rear Billsteins?
  4. Nov 8, 2011 at 7:47 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    It depends how much you want to lift it & if you want to keep factory rake (rear higher). It will ride better with 5100s in the rear also but no it isn' t required. If you get an AAL get the longer 5100s for the rear.
    A locals Taco. He has the TSB leafs
  5. Nov 8, 2011 at 7:05 PM
    jarpil
    Kalaheo, HI
    I have not decided yet but this is what i am thinking about:
    Toytec lift kit: I will get Moto Metal 951 16/9 wheels with 285's M. Thompson Baja ATZ tires.
    Do i need differential drop kit and new UAC's?
  6. Nov 8, 2011 at 7:42 PM
    jarpil
    Kalaheo, HI
    Are the longer ones included in the kit i mentioned?
  7. Nov 8, 2011 at 11:26 PM
    4Wheelin4Banger
    Randy
    No on the diff drop.
    Debatable on the UCAs. Some say yes, some say no, Some say maybe.
    I am runnining stock UCAs and it drives fine with stock 245/75/16s.
    I've heard with larger tires they may be nessasary. I'm going to get 265/75/16s and will see what it drives like.
    I would ask ToyTec before ordering.
    From the Downsouth Motorsports website:
    0" to 1.5" Rear Lift on NON-TSB leaf springs, Shock Part #: BE5-C478-T0
    Extended Length: 22.94"
    Collapsed Length: 14.02"
    3" to 4" Rear Lift Shock Part #: BE5-B110-T5
    Extended Length: 27.28"
    Collapsed Length: 16.34"
  8. Nov 9, 2011 at 2:30 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    With a 2" rear lift the longer ones will be cutting it close. The compressed length may be an issue.
  9. Nov 9, 2011 at 6:52 AM
    4Wheelin4Banger
    Randy
    He's talking TSB leaf pack & AAL. I think the TSB leafs add 1 1/2" and the TSB AAL is 1 1/2" for a total 3" lift.
  10. Nov 15, 2011 at 8:09 PM
    jarpil
    Kalaheo, HI
    Still have not decided what to do yet.... :( Put new wheels on with AT 265's BFGoodrich tires. Now i am thinking about the lift. Got an estimate for OME lift from a local 4wd shop. They want $450 just to install the lift which i think is little too steep.
  11. Nov 15, 2011 at 10:36 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Just get 5100's all around and set the front at 1.75" w/ 1.5" aal. Don't get the longer rear shock because the tsb only adds 1/2" I believe.
    Edit - OME is a good choice too! Your prob looking at 4hrs of work for a shop to do either setup!
  12. Nov 16, 2011 at 6:35 AM
    4Wheelin4Banger
    Randy
    It's not hard to install a lift. Another TW member and I did two complete lifts in under 4 hours with some help from my wife.
  13. Nov 16, 2011 at 7:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    $450 doesn't seem that steep for 4 hours of shop time
  14. Nov 16, 2011 at 10:07 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Maybe not it canadian dollars!
  15. Nov 16, 2011 at 10:10 AM
    OZ-T
    Peter North
    British Columbia
    The dollar is at par !!!!
    How much is a shop rate down there ?
  16. Nov 16, 2011 at 12:29 PM
    jarpil
    Kalaheo, HI
    The quote is for 6 hrs at $75/hr. Also the OME kit he is selling is 100 bucks more then i can get it online + $52 freight which is ok.
  17. Nov 16, 2011 at 12:34 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    she sounds like a keeper.:cool:
