Another motor oil debate.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The OR LB 16, Apr 15, 2016.
  1. Apr 16, 2016 at 11:08 AM
    #41
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
  2. Apr 16, 2016 at 11:35 AM
    #42
    Joe D
    Joe D .
    So the concern is the "20" in 0w20?
    Cold or hot outside, once the motor reaches its normal operating temperature the viscosity will be ~20 unless the motor overheats or is unable to achieve its normal operating temperature.
  3. Apr 16, 2016 at 11:42 AM
    #43
    Clearwater Bill
    Billy
    Largo Florida
    On a vehicle that is not overladen and has a fully functional cooling system operating as designed, ambient temperatures should only affect startup conditions and length of time to reach operating temperature.
    After that, the internal temp of the engine is regulated primarily by the cooling system and secondarily by adequate oil volume and circulation.
    Once at operating temperature (cooling system controlled) measured oil temps should be very close for comparable vehicle operating conditions regardless of ambient.
    OTOH, what your butt feels when you slap it in the seat is another story.
    Blazingbluesport, daddy_o and Joe D like this.
  4. Apr 16, 2016 at 1:30 PM
    #44
    The OR LB 16
    The OR LB 16 [OP] Well-Known Member
    Tom
    Tacoma 2016 TDR Off road LB
    I am in Arkansas . It very seldom gets below 15 degrees F and then only for a day or 2 . Most winters here have few days below 20 F . In the summer We have had weeks in a row above 100 F , but most of the summer is high 80's to 100 . As far as having an issue , if a vehicle is only kept for 5 years and low miles it is no big deal .
  5. Apr 16, 2016 at 1:51 PM
    #45
    The OR LB 16
    Tom
    I did some more research today and found that the 3.5L in the Camry has the same changes in the USA manuals as compared to the Europe manuals . Slightly different engines than the tacoma but both are VVT-i . USA wants only 0W20 but Europe can use up to 20W50 . Its a CAFE thing !
  6. Apr 16, 2016 at 2:18 PM
    #46
    Joe D
    Joe D .
    We're almost neighbors.
    My vehicles are definitely not low milage. I drive 40k+ miles a year and pull sometimes at max GVWR.
    I've not looked up the ratings for the 3.5l EU motor you reference but, are they using API / SAE J300 standard?
  7. Apr 16, 2016 at 2:28 PM
    #47
    judgeman6970
    judgeman6970 Well-Known Member
    Bob
    Long Island, NY
    A forum will never agree on what oil is best, but imo, 0w-20 only exists for epa/mpg's. My '14 uses 5w-30, but I'll never run anything lighter/thinner than that in any vehicle I own. That's what I like about America, we can all make our own choices!(at least for now?) :thumbsup:
    The OR LB 16[OP] likes this.
  8. Apr 16, 2016 at 2:32 PM
    #48
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
  9. Apr 16, 2016 at 3:48 PM
    #49
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Element FTMFW :)
  10. Apr 16, 2016 at 4:18 PM
    #50
    thefreshtaco
    thefreshtaco Well-Known Member
    Indianapolis Indiana
    2016 White TRDOR DCSB M/T Tech
    All DOHC four cylinders since around 03ish have chains now. Replace them all the time.
  11. Apr 16, 2016 at 10:22 PM
    #51
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    If they really cared about that they'd full their fluid s properly from the factory and make some sort of scan tool that actually read the levels properly instead of the POS scan tool they have now.
    I'm not saying Toyota is purposely recommending an oil that won't stand up to the engines intended design and uses, but that they dropped the ball with the 16s and aren't really holding up their reputation for quality and reliability.
    Kaerntner and The OR LB 16[OP] like this.
  12. Apr 16, 2016 at 10:51 PM
    #52
    digitaLbraVo
    @Mr. Torgue as someone who does not defend 2016 trucks at all around here, I do challenge you to show me a single auto manufacturer who rolled out a new make/model/redesign and the first generation of that release being perfect.
  13. Apr 17, 2016 at 2:27 AM
    #53
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    The transmission/differential fluid fill issue is from the second generation of Tacomas. Should have been fixed a long time ago.
  14. Apr 17, 2016 at 7:11 AM
    #54
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    A scan tool to check transmission fluid level?!?!?!?! Really?!?!?!? It really just needs to be visually checked after the truck is started/tested. Toyota doesn't need to add a bunch of sensors and develop a new tool for this. That's just silly.
    It's a whole different group of people involved in the design of the engines vs. the assembly line folks.
    daddy_o likes this.
  15. Apr 17, 2016 at 7:13 AM
    #55
    Woodrow F Call
    Colorful Colorado
    I honestly think people are overthinking this.
    Blazingbluesport likes this.
  16. Apr 17, 2016 at 8:02 AM
    #56
    The OR LB 16
    Tom
    Take a look at the oil recommendation chart in the owners manual for the Tacoma on page 571 . Note that the tip of the arrow for the range of use for 0W20 stops approx. 3/4 of the way between 80 degrees and 100 degrees . in my calculation that is 95 degrees . I see this on other charts from different engines etc. , is the point is of all the different viscosities listed up to 20W50 top out . Does this mean that Toyota does not except responsibility for any thing that happens to the engine when it is used while it is above 95 degrees outside ?
  17. Apr 17, 2016 at 8:05 AM
    #57
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Not a single problem with my first year 2005 Tacoma, it is perfect.
  18. Apr 17, 2016 at 8:32 AM
    #58
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    They already use a scan tool and call it good even though the thing doesn't even properly read if a transmission is low. It's a joke. They never should have taken out the dip stick.
  19. Apr 17, 2016 at 8:49 AM
    #59
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    So are you going to run something different than the OEM recommended oil?
    Joe D likes this.
  20. Apr 17, 2016 at 9:33 AM
    #60
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Nope. I'll stick to a 0w20 of some sort
    smitty99[QUOTED] likes this.
