Another motor oil debate.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The OR LB 16, Apr 15, 2016.
  1. Nov 5, 2016 at 9:40 AM
    #101
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I'll need to check the dealers here in Ontario. Wonder what it will cost. Hell I pay $90 an oil change for jetta and it only holds like 4L lol
    Motul Pro Spec 8100 though, might be the reason its so much more.
  2. Nov 5, 2016 at 9:41 AM
    #102
    Joe23
    I wonder how much of a difference there is between Castrol, Mobil 1, Royal Purple, Motul etc when it comes to the 0w-20
  3. Nov 5, 2016 at 9:43 AM
    #103
    Joe23
    yes
  4. Nov 5, 2016 at 9:47 AM
    #104
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I have multiple vehicles to drive. My own, family members, customers, lot cars, etc. someone always needs something worked on/driven
    Joe23[QUOTED] likes this.
  5. Nov 5, 2016 at 9:48 AM
    #105
    Joe23
    2006 Jetta TDI meets higher spec than what VW recommends and I've been running it for years no problems. lol
    I'll continue to do so. Besides engine is far from stock, I've tried other oils and noticed a difference
    Hoff[QUOTED] likes this.
  6. Nov 5, 2016 at 10:06 AM
    #106
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    MOBIL 1 on sale at Canadian tire and Walmart is like $34.95 for 4L or 4.4L
    unless you're talking about properties not price Lol
  7. Nov 5, 2016 at 10:25 AM
    #107
    Joe23
    I meant properties lol.
    You'll pay more for royal purple and motul, but I wonder if its really any different from the others.
  8. Nov 5, 2016 at 11:20 AM
    #108
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I knew a guy that told me the first thing he did with any engine was pull the thermostat out and throw it away. "These engines run too hot, it's crazy." Obviously he was smarter than the people that designed the engines and looked at tolerances while running the crap out of them on dynamometers.
    The last time I saw him he was pulled off the interstate with his hood up. I was headed the other direction so he was on his own.
    SB
    p.s. This is what the manual says:
    "If SAE 0W-20 is not available, SAE 5W-20 oil may be used. However, it must be replaced with SAE 0W-20 at the next oil change."
    Hoff and Joe23 like this.
  9. Nov 5, 2016 at 11:27 AM
    #109
    Joe23
    I do my changes every 8000km
    Cant remember if Motul is german or french.
  10. Nov 5, 2016 at 11:35 AM
    #110
    Joe23
  11. Nov 5, 2016 at 12:16 PM
    #111
    the_dau
    Vancouver BC
    If you want expensive, get LiquiMoly
  12. Nov 5, 2016 at 12:54 PM
    #112
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    jsi likes this.
  13. Nov 5, 2016 at 1:11 PM
    #113
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I just changed the oil in my rig. I went with a high-end coffee filter....not some no-name Walmart crap, but a good quality Mr Coffee filter. Filled it with 5.5 qts of all natural piss. I'll admit that it took awhile to get that much out. But I did it. Thank Miller Lite.
    jsi, Joe23 and Sig45 like this.
  14. Nov 5, 2016 at 6:34 PM
    #114
    Jimkola
    Jimkola Active Member
    Jim
    2017 Tacoma 4wd access cab
    Other than shell, stock
    Yeah, 30 years later and oil discussions still going strong.
    Just change it on time, don't mix brands, and most arguments are pretty moot.
    As a service manager people would try to get me to enter into these debates. Changed properly, all API certified oils are good. If you want to find out which oil you can just abuse and neglect and have it still work, well, your on your own on that one. Let me know what you find out.
  15. Nov 5, 2016 at 7:23 PM
    #115
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... LOL ... exactly ...:thumbsup:
  16. Nov 5, 2016 at 7:27 PM
    #116
    SOSHeloPilot
    2024 4Runner SR5
    ...^^^... Ditto ... 3 changes at 6,400 miles ... :)
    Aussiek2000[QUOTED] likes this.
  17. Nov 6, 2016 at 8:43 AM
    #117
    jsi
    jsi Well-Known Member
    native earthling
    ▲▲▲ This ▲▲▲ is the best oil debate post ever
    because
    ▼▼▼ This ▼▼▼ is the best oil debate point ever
  18. Nov 6, 2016 at 9:29 AM
    #118
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Look up Mobil 1 5w-30 in Subaru EJ20 turbo motors if you want to see a shocking oil trend.
    That being said, I will give my uncalled for $0.02 on the issue. I don't like how light the oil specs are on most new cars, but I'd be inclined to think that the driving force is CAFE standards rather than ultimate oil protection. That being said, your average dealer will use 0w-20 at the standard 10,000 mile interval because that's what Toyota calls for. The average consumer won't be driving the trucks hard enough to wreck the oil enough that it's dangerous (when is the last time the average consumer even CHECKED their oil, let alone thought about it).
    I personally am not a fan of the extended intervals, at least not without running UOAs on my own oil with my own driving style and I will probably change at 5,000 intervals. I'm sure it's throwing away money, but it's piece of mind. Since I don't really want to get into a warranty war if someone does go south, I will run the standard dealer issue 0w-20 at least until the 5/60 is up and then decide if I want to go heavier. That being said, if I was planning on driving the truck harder, towing regularly in high heat, etc, I'd probably run German Castrol Syntec 0w-30. I ran that in my STi (a car known for being hard on oil) for 40,000 miles without a hiccup with the UOAs to prove it.
    SOSHeloPilot likes this.
