Another mowing season off to a bad start! Please Advise
Discussion in 'Garage / Workshop' started by CNEDEER, Mar 25, 2012.
  1. Mar 25, 2012 at 5:57 PM
    CNEDEER
    CNEDEER [OP] If ya ain't first, your last!
    2015 DC TRD OR 4x4
    So, just got done tuning up the mower, or so i thought.
    Put new blades on it, changed the oil, etc.
    Got underneath the mower, drive belt is off! Thought no big deal, so I popped that sucker back on.
    Go to start the mower, and it starts fine. However, when I put it into gear, it doesnt even move??? What could this be??
    Mower is a Craftsman Kohler Pro 20 V-Twin 54 inch deck. It has 6 gears in the middle right in front of the seat, to the right it has a lever where you select low gear or high gear. I don't believe the brake or anything is stuck as I can push the mower when in neutral. Is this a transmission problem or?? Not very savy when it comes to anything mechanical, but I have learned a little bit over the years.
    Any ideas or remedies? or thoughts as to what it could be?
  2. Mar 25, 2012 at 6:00 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Could be a stretched belt. I feel your pain because I run a mini one man lawn care company and nothing works no matter how well you winterize the equipment.
  3. Mar 25, 2012 at 6:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Sounds like either you need a new belt.....or don't have it around the pulleys the right way.
  4. Mar 25, 2012 at 6:03 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Well yesterday when I put the drive belt on , it took all I had to get it back on due to it being so tight. I guess that wouldn't be the worst case scenario if it needed a new belt.
    **Just had a thought, I am able to push the mower when in neutral. If I shift it into a different gear, and I am unable to move it, will that mean the transmission is functioning properly and therefore its not a trans problem?
  5. Mar 25, 2012 at 6:14 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Could the trasmission or transaxle be bad. The pulley next to the trans seems to be spinning properly, which leads me to believe there is something wrong with it , or no?
  6. Mar 25, 2012 at 6:19 PM
    Warhorseforever
    Will
    Sand Lapper
    Did you put the pulley back on right? If you can't move it while it's in gear then it most likely is not a trans problem, maybe you didn't put it on the tensioner? The part that puts pressure on the belts and pullies.
  7. Mar 25, 2012 at 6:23 PM
    CNEDEER
    2015 DC TRD OR 4x4
    I'm going to go shift it into gear real quick and see if the mower moves. If it is in gear and doesn't move, does that eliminate a transaxle problem?
  8. Mar 25, 2012 at 7:19 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Just went outside and put mower into gear and it wouldn't move, does that mean its not a trans problem??
  9. Mar 27, 2012 at 7:38 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    It doesn't sound like the transmission. Check to make sure the tensioner is putting proper pressure on it. Sometimes the springs on the tensioners wear out. I had to replace one of the tensioner springs on my commercial walk behind mower last year.
