Another new battery drained within 3 weeks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by damian12, Dec 10, 2020.
  1. Dec 10, 2020 at 5:20 AM
    damian12
    damian12 [OP] Member
    Wisconsin
    2019 Tacoma
    Hi all,
    2019 Tacoma needed a new battery after about 11 months. now it's 9 months later and the truck sat for 3 weeks and it would not start. it was not totally dead, but not enough juice to turn it over. I have read about Toyota batteries being crap, but what's the chance of another one going bad? Can our vehicles sit 3 weeks without a charge? I do have aftermarket head unit and Viper remote start. By the way it was only around 30 degrees f here during that time so it's not the like the dead of winter.
  2. Dec 10, 2020 at 5:34 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    If you put a battery tender on it, It'll probably bring it back to life, unless a cell is dead. Get the multimeter on it like @whatstcp said though
    whatstcp, eurowner and DAS Taco like this.
  3. Dec 10, 2020 at 5:44 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    They should have at least a one year warranty. Take that crap back
    BlackTRD4Me, BalutTaco and kgilly like this.
  4. Dec 10, 2020 at 5:56 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Just 2 months shy of my manufacturer's warranty expiring, Toyota replaced my battery free because of a bad cell. Take it back to the dealer and let them deal with it while you are under warranty.
    Thaitoy likes this.
  5. Dec 10, 2020 at 6:00 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Finding a low current draw takes patients it is not easy. All of the fuses under the hood are live circuits (hot with the key off) some times a test light works some times it doesn't connect the clip to the battery the tip to the cable if it lights you have enough current to kill the battery over time. The other method is a current reading multi meter. If you see a current draw start pulling fuses one at a time until the draw goes away. All modern stuff has a parasitic draw to some extent. 9 months is a long time with out some recharge google "solar battery tenders" you will need one with battery clips because the lighter socked is dead with the key off.
    Thaitoy likes this.
  6. Dec 10, 2020 at 6:11 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    You should have led with this...your problem is more than likely being caused by one or both of these things. I've had zero issues with the stock batteries so far, to include prolonged periods of no driving for 3+ weeks.
  7. Dec 10, 2020 at 6:12 AM
    mhornco
    mhornco Well-Known Member
    We have a bunch of trucks from different manufacturers sitting on out lot at work (Dodge, Ford, Chevy) if any of them sit for more than a couple weeks they need to be jumped. Parasitic draw is common to all modern vehicles. Your aftermarket stuff may cause further issues as well as it is continuously monitoring things, thus always drawing some power.
  8. Dec 10, 2020 at 6:24 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    Had it happen to my Tundra a couple times. Couldn't figure out why my battery kept draining and dying. It was the dang tailgate, license plate bulbs which would never shut off for some reason. I just pulled the fuse to it. Didn't know originally what caused it because I always back into my garage, into a big foam pad and could never see it on.
  9. Dec 10, 2020 at 6:26 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    That's how you get pulled over around here!
    CalcityRenegade likes this.
  10. Dec 10, 2020 at 6:28 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Does your viper remote start have a flashing led inside the truck somewhere to show its locked? My old car has this with the viper system and it drained my battery after about 2 weeks of sitting.
  11. Dec 10, 2020 at 6:33 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    It is absolutely not normal for a Tacoma, or any other vehicle with a good battery to need a jump after just two weeks of dormancy.
    Be it a bad battery or an abnormal draw on a good one, the OP has something wrong with his truck.
  12. Dec 10, 2020 at 6:34 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I really can’t offer you a solution myself but what I tell you comes from an installer with over 25 years under his belt. He told me Never put a viper system in a Tacoma. He said Nothin’ but trouble. Won’t install ‘em & won’t work on ‘em either.
    Hobbs likes this.
  13. Dec 10, 2020 at 7:24 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Put it on a decent trickle charger (Noco or Ctek) or just disconnect it...oem batteries are like the oem tires...and that's not just Toyota.
    oconnor likes this.
  14. Dec 10, 2020 at 7:41 AM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Idk my company had a fleet of about 50 35 of those being Tacoma’s the other f350s and if they weren’t on a tender and temps dropped below freezing it was pretty normal for the batteries to die after 2-3 weeks.
    weefek and jmneill[QUOTED] like this.
  15. Dec 10, 2020 at 7:43 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    That sucks, I have the original battery since dec 2016, so on it 5th NH winter and sucker is still very strong.
  16. Dec 10, 2020 at 8:03 AM
    jmneill
    SE
    Yep, prolonged temps below freezing, I wouldn't doubt it. My post was addressing parasitic draw, specifically.
    OP is indicating what I presume to be night time lows around 30° in his AO.
    In his case, I'd say the smart money is still on a bad battery or something killing it.
    Hopefully he'll get back to us with the answer.
  17. Dec 10, 2020 at 8:06 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    I’ve heard most dealer supplied batteries are Interstate with a Toyota sticker.
  18. Dec 10, 2020 at 8:15 AM
    jmneill
    SE
    I pulled mine and replaced it with an AGM, but threw the OEM on a trickle for a spare.
    The sticker reads 'Distributed by Toyota Motors, Manufactured by Johnson controls.'
    (Interstate)
  19. Dec 10, 2020 at 8:22 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Get you self a amp meter, take the negative battery cable off, hook one lead of amp meter to the cable removed and the other lead to the neg battery post. Put the amp meter on miliamp scale. [MAKE SURE KEY IS OUT OF IGINITION] Wait 30 minutes to the modules go to sleep. you want to see the miliamps under 50. this is normal. anything over that will bring down the battery. If over 50 start removing one fuse at a time till the drain drops down to specs. If no drain found like that, start removing the main cable to the alternator and so on. Hope this helps you, good luck...
    MauiBrian likes this.
  20. Dec 10, 2020 at 8:27 AM
    bulldawg5737
    bulldawg5737 Well-Known Member
    2019 TRD Off Road
    My 2cents: my taco will sit stored for 1-2 months at a time twice a year. I've put an Optima Yellow-top in two months after purchasing the truck and it has never failed to start, worth the investment IMO.
