Another "Noise" thread...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris24, Aug 10, 2016.
  1. Aug 10, 2016 at 12:08 PM
    Chris24
    Chris24 [OP] Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    09 V6 DCSB 6 speed with ~90K miles. Truck recently started making a really nice noise when i accelerate hard. I would describe it as a "rattle" from underneath the truck. There is just the noise - no clunks or whines. Only happens when accelerating - can't reproduce when revving, coasting, or idling. All U-Joints seem tight, all heatshields seem solid (even the one around the cat), exhaust seems fine. I have banged on everything i can under the truck with a deadblow hammer with no luck and have greased the u joints also with no improvement. Tried to get it on camera but you can't hear it over my Magnaflow muffler.
    Any suggestions? :confused:
  2. Aug 10, 2016 at 12:20 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
  3. Aug 10, 2016 at 12:35 PM
    Chris24
    Greensboro, NC
    Skyway[QUOTED] likes this.
  4. Aug 10, 2016 at 12:37 PM
    Skyway
    Ande'
    St.Pete
    You know that right side forward bolt that holds the bed to the frame?
  5. Aug 10, 2016 at 12:42 PM
    Chris24
    Greensboro, NC
  6. Aug 10, 2016 at 12:51 PM
    Skyway
    Ande'
    St.Pete
    Chech to see if the bed is slipping up and down on the bolt forward right side....
  7. Aug 10, 2016 at 12:53 PM
    Chris24
    Greensboro, NC
    I will check that...seems to be a "fast" rattle noise though.
  8. Aug 11, 2016 at 10:21 AM
    Chris24
    Greensboro, NC
    Could a bad carrier bearing or u joint make a "rattle" noise when accelerating?
  9. Aug 31, 2016 at 7:47 AM
    Chris24
    Greensboro, NC
    bed bolts are tight.
    noise ONLY happens when I am pressing the accelerator...if I let off, it stops...I tried a tank of premium to see if it was knock but that didn't change anything.
    any other ideas?
  10. Aug 31, 2016 at 8:00 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I think your catalytic converter is failing.
    10trdtaco likes this.
  11. Aug 31, 2016 at 8:03 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    This. Seems to be a common issue causing the noise as you have described it.
  12. Aug 31, 2016 at 8:46 AM
    Chris24
    Greensboro, NC
    hmm, I tried banging on them but they didn't make any noise...any way to see which one it is?
  13. Aug 31, 2016 at 8:59 AM
    Nighthawk
    Levi
    Casper Wyoming
    Does it make the noise when you cold start it?
  14. Aug 31, 2016 at 9:00 AM
    Chris24
    Greensboro, NC
    idling? no noise. i have noticed the noise as soon as i start driving, though
  15. Aug 31, 2016 at 9:02 AM
    T4RFTMFW
    Sit in park and rev the throttle.
  16. Aug 31, 2016 at 9:04 AM
    Nighthawk
    Levi
    Casper Wyoming
    Well what I'm wondering is if you hear it slightly right when you start it up and the RPM's overshoot a little bit. In that case you could have someone else start it while you are underneath and possibly help identify which one it is.
  17. Aug 31, 2016 at 9:07 AM
    Chris24
    Greensboro, NC
    tried that a few weeks ago, no noise at all
    will try this tonight
  18. Aug 31, 2016 at 9:33 AM
    T4RFTMFW
    Trying to remember if my cats rattled in park or only when under load.
    :pout:
  19. Aug 31, 2016 at 9:35 AM
    T4RFTMFW
    Does it sound like a hollow rattle sound or a hard rattle sound? Hollow like some rice in an oatmeal container, hard being like throwing rocks against a fence.
  20. Aug 31, 2016 at 9:36 AM
    Chris24
    Greensboro, NC
    rocks against a (metal) fence
