Another noob question about shocks
Discussion in 'Suspension' started by Vikinglord, Mar 3, 2012.
  1. Mar 3, 2012 at 6:11 AM
    Vikinglord
    Vikinglord [OP] Active Member
    Michael
    Nashville
    Gold Prerunner
    Hello everyone. I have read many of ther post under the suspension section, including the sticky's and this: http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
    But now I am a bit confused. I just had Michelin LTX MS 2's on my 06 Taco and it is quieter and smoother, but it seems I feel every bump in the road. I am looking for a smoother ride, but do not care about lowering or raising the truck. This one does not go off-road.
    I know this is a truck and not a Mercedes, but I am just looking for a slightly smoother ride. Maybe I am in the wrong forum? Just need some advice from you all.
    Thanks for any help.
  2. Mar 3, 2012 at 6:14 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    The 5100's get great reviews all the time on TW you should be quite pleased with them...
  3. Mar 3, 2012 at 6:25 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Have you checked your air pressure? No shop is going to chalk test and dial in the pressure like a owner should. I would suggest starting there first. Also what load rating are your new tires?
  4. Mar 3, 2012 at 12:24 PM
    Vikinglord
    Michael
    Nashville
    Gold Prerunner
    They are brand new Michelin ATX MS 2's with Nitrogin, 265\70\16's. 35 psi.
  5. Mar 4, 2012 at 5:11 AM
    XXXX
    sKiP
    05 Prius
    That does not answer anything I asked.
  6. Mar 4, 2012 at 6:33 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    VikingLord,
    I think you will be pleased with either Bistein 4600s or 5100s for your intended use. The chalk test on your tires has you draw a line across the tread of your tire and drive a short distnce to see if the chalk wears off evenly. Wear in the center only would indicate over pressure. Drop the pressure slightly and repeat the test. This gives you the best tire pressure for "your" truck, individualized for it's weight.
