Another noob wants to lift his 5 lugger
Discussion in '5 Lug' started by paquu, Mar 13, 2013.
  1. Mar 13, 2013 at 10:32 PM
    paquu
    paquu [OP] Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Hey guys. I've been browsing these forums the past few days because I'm interested in lifting my 5 lug 2000 Tacoma (in attachments). I figured I'd just make an account to see if I understand things correctly. From what I've read, I can either go with a spacer kit or spindles. I've read that spindles are the better way to go, but I'm not sure why.
    Here is what I think I need:
    a 3" spindle lift kit, including shocks, and a rear AAL
    found here:
    http://www.rockymountainsusp.com/toyota2.htm
    a set of cragar soft 8's
    (what size do you recommend?)
    and some tires for these ^
    What else am I missing? Do I need a differential drop? or no because its RWD. Do I need a longer brake line? What are your thoughts?
    Thanks
  2. Apr 30, 2013 at 10:40 AM
    okspeed
    okspeed Active Member
    TX
    07 Taco
