Another noob wants to lift his 5 lugger
Discussion in '1st Gen. Tacomas (1995-2004)' started by paquu, Mar 16, 2013.
  1. Mar 16, 2013 at 7:47 AM
    paquu
    paquu [OP] Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Hey guys. I've been browsing these forums the past few days because I'm interested in lifting my 5 lug 2000 Tacoma (in attachments). I figured I'd just make an account to see if I understand things correctly. From what I've read, I can either go with a spacer kit or spindles. I've read that spindles are the better way to go, but I'm not sure why.
    Here is what I think I need:
    a 3" spindle lift kit, including shocks, and a rear AAL
    found here:
    http://www.rockymountainsusp.com/toyota2.htm
    a set of cragar soft 8's
    (what size do you recommend?)
    and some tires for these ^
    What else am I missing? Do I need a differential drop? or no because its RWD. Do I need a longer brake line? What are your thoughts?
    Also, would it be possible to switch to all adjustable shocks to get the lift I want? Wouldn't this be easiest?
    I tried posting on the 5 lug part of the forum a couple days ago and haven't gotten an answer.
    Thanks!
  2. Mar 16, 2013 at 6:15 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Im pretty sure the diff drop is for the front CV axles...so no I wouldn't think you'd need a diff drop.
  3. Mar 16, 2013 at 6:22 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2001 TRD Off-road Prerunner V6
    Icons, Konig Countersteers, BFG A/T's
    I know this really doesn't answer ur question but why not just trade it in for a prerunner? Also, diff drop is for 4x4s only
  4. Mar 16, 2013 at 8:06 PM
    Taylor
    Taylor Wants to learn all about his Taco.
    Taylor
    Lynchburg/Harrisonburg Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    I don't think you'll need to extend brake lines unless you plan on wheeling, but they'll be VERY close to needing it.
  5. Mar 16, 2013 at 10:52 PM
    paquu
    RI
    42" LED bar
    Okay great. Thank you for responses.
    Unfortunately I can't trade the car in as it was a gift.
    I don't plan on doing any off roading.
    I'm thinking I can buy the spindles, as well as the AAL and shackle from here:
    http://performancelifts.com/fabtech-tacoma-3-lift-spindle-fts4130-7.html
    and a pair of rear bilstein 5100's. (mine need to be replaced)
    However, with 2" shackles, and 1.5" AAL's will the bilsteins even fit correctly? Would I need an adjustable 5100?
    Again, this is a 5 lug '00 Tacoma
  6. Mar 16, 2013 at 11:21 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I don't think 5100's were designed to fit on 5 lug trucks.
    I have no idea who makes, or where to buy extended shocks for a 5 lug, except for the fabtech ones you can buy for that kit.
  7. Mar 16, 2013 at 11:29 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  8. Mar 16, 2013 at 11:50 PM
    paquu
    RI
    42" LED bar
  9. Mar 17, 2013 at 12:00 AM
    95 taco
    95 taco Battle Born
    i have the doetch spindles, i didn't measure for how much lift, but i can get you hub to fender measurements tomorrow morning.
    the spindles kicked the tires out a good bit, but we also put wider than stock tires on.
    i also put the doetch shackle lift on the rear, it's 3''s.
  10. Mar 17, 2013 at 12:20 AM
    paquu
    RI
    42" LED bar
    Hey that'd be great. And how much larger of a tire could you have put on? I'd like mine to sit higher than that if possible. I don't know if that's just an optical illusion of the shadow underneath.
    I'm also not sure if I like how much the front was pushed out. I know you said you got extra wide tires though. How much do you think the spindles pushed the wheels out? like an inch?
  11. Mar 17, 2013 at 12:38 PM
    95 taco
    95 taco Battle Born
    from the bottom of my frame to the ground its 10 inches, the tires are 1'' bigger than stock, so with stock tires the frame would sit 9 inches above ground.
    i thought i had wider tires, but i just ran the tire size calculator and my tires are the same width as stock, so part of my width is backspacing (or offset, i'll figure it out and measure later).
    it sticks out ~3 inches, but that can be fixed with a slightly narrower tire, and proper backspacing (?).
    my back tires are almost on the outside of the wheel well, so i can measure outside-outside and get you the difference, but i'm not sure if the front and rear are the same track width stock.
    and stock tires won't work with the spindles, maybe with a small spacer. i think i rubbed on the spindle when i tried to see if they would fit.
  12. Mar 17, 2013 at 12:53 PM
    95 taco
    95 taco Battle Born
    difference it front and rear track width is ~ 2'' each side, so the spindles kick the tires out about 2'' each side.
    i'm not sure how accurate these measurements are as it's hard to measure by yourself, but they should be accurate within 1/2''.
  13. Mar 17, 2013 at 7:45 PM
    paquu
    RI
    42" LED bar
    Well I thought ours looked close. Mine is 9" ground to bottom of frame, and mines stock. Your LIFTED height is 10"?
  14. Mar 17, 2013 at 7:59 PM
    95 taco
    95 taco Battle Born
    Yep, not sure if the person who used to own the truck lowered it?
    There was definitely some lift when we put the spindles on.
    There's another lifted 5 lugger on here, I think his username is joels98taco, we could ask him what his measurements are.
    He has a 3" lift I think.
  15. Mar 17, 2013 at 8:00 PM
    paquu
    RI
    42" LED bar
    I headed over to the customtaco forum. Someone also had a 5 lug 2WD with a fabtech 3" spindle + 1.5" coil spacer. Granted, its 1.5" larger, but from pictures alone, comparing your front lift to his, that's a very large/noticable 1.5" difference.
    (picture here)
    http://gyazo.com/7e73a6d76ba386ffd554a1fcb73fd83c
  16. Mar 17, 2013 at 8:04 PM
    paquu
    RI
    42" LED bar
  17. Apr 3, 2013 at 10:00 AM
    sbsurfer
    sbsurfer Well-Known Member
    2000 Reg Cab 4x4 4cyl 5spd
    I had a 98 Tacoma 2wd 5 lug a while back. I put the Fabtech 3 in spindle lift on it with some raised shackles in the rear. I wanted that prerunner look with the higher front end and it came out pretty sweet. I think i ran 30's on it, which was as big as i could go. I didn't have to mess with brake lines or anything and had no troubles with the truck after the lift. The front track does widen a bit...i will say with the larger tires and NOT regearing the rear end the truck lugged around a bit...just a heads up if it's a 4 banger.
  18. Apr 3, 2013 at 1:33 PM
    PRBond
    PRBond Well-Known Member
    Patrick
    Columbus, OH
    04 TRD PreRunner
    3" ToyTec suspension kit, AEM Air Intake, Uniden 510 CB, 265 X 75 X 16 BFG AT's
    Do you have pics? My younger brother also has a '98 2wd 5 lug that he's been talking about putting that exact same kit on.
    For the last year I've been trying to talk him out of it, because I didn't think he was going to get the same ride quality that he's had by leaving it stock.
  19. Apr 3, 2013 at 7:25 PM
    sbsurfer
    I looked around for a while and couldn't find any pics, sorry man. At the time it was all I could afford and pretty much the only option for the 5 lug. When i bought the truck it had a body lift and bigger tires...the body lift had to go immediately, hence the spindle lift. I liked how it widen the front a bit and with billys the ride was pretty good. The only drawback was the gearing for me cause i left it stock and with the large tires the 4cyl lugged a bit...but not too bad. I drove that truck like that for about 60,000 miles with zero issues. If i could do it all over i would have sold the 5 lug and got a prerunner....but life's all about making mistakes :D
  20. Apr 8, 2013 at 4:37 PM
    sbsurfer
