another of my double cab rattles solved
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jtifm, May 24, 2017.
  1. May 24, 2017 at 4:58 PM
    jtifm
    jtifm [OP] Well-Known Member
    2017 TRDORDCSB
    I was getting a plastic-type rattle from the rear seat area, sounded like the seat belts or something in a cargo bin. Hard to isolate without having someone to drive me around. This was an impact rattle, expansion joints, pavement cracks. Turned out to be the grab handles. Looking at them, one side has a spring-not the problem. The other side is loose due to the lack of the spring and if you tap you will find a lot of slop. I am sure felt would work. I had an assortment of rubber plugs left over from the a-arm fix and a couple of them fit quite nicely in the handle cutout. Problem solved.
    ajmogen, Hiluxski, shakerhood and 2 others like this.
  2. May 24, 2017 at 7:34 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    good job OP
  3. May 24, 2017 at 11:49 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Holy shit. I had a rattle that didn't go away until my mom sat in the back seat. She always uses those handles. She must have pulled it and fixed something inside it
    Wow thanks
    The hammer likes this.
  4. May 25, 2017 at 12:38 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    You know what might be the cause of the rattle i have under my dash on the passenger side? It comes around under light acceleration. Just curious. Haha
  5. May 25, 2017 at 1:07 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Dash speaker cover
  6. May 25, 2017 at 1:10 AM
    Hilborn
    Michael
    Utah
    The one in the door panel? ill check that out in the morning. Thanks.
  7. May 25, 2017 at 1:31 AM
    shakerhood
    Southern Ohio
    The one on the passenger side dash is a source of noise for many, it rubs on the A pillar if not mistaken
    Oldman808 likes this.
  8. May 25, 2017 at 2:56 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    If you had a 3rd Gen I could probably suggest a few things..
    shakerhood likes this.
  9. May 25, 2017 at 7:14 AM
    jtifm
    2017 TRDORDCSB
    I read a post a while back about a wiring harness in the area under the glove box. Tapping on the blower housing or something. Have a look. There is also a wire harness under the passenger seat that gets close to the plastic floor vent depending on how the seat is positioned fore to aft.
  10. May 25, 2017 at 8:12 AM
    shakerhood
    Southern Ohio
    I did not even notice he has a 2nd Gen
  11. May 25, 2017 at 8:25 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Great job OP, you nailed it!
  12. May 25, 2017 at 8:44 AM
    Hilborn
    Michael
    Utah
    I dont care what gen. Should looking for ideas. It drives me crazy.
  13. May 25, 2017 at 8:58 AM
    shakerhood
    Southern Ohio
    I agree it should not be rattling but my advice applied to 3rd Gens
  14. May 25, 2017 at 9:25 AM
    Hilborn
    Michael
    Utah
    I know. But when in need, you will grab any source you can.
  15. May 25, 2017 at 9:36 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I have noticed a rattle on rough surface the last week. Just checked my grab handles. Both are loose. Add that to the list for my 10K service. Along with my radio randomly going to split screen on start up. Already had it replaced once for that. There is a reflash to fix it. First radio wouldn't reflash.
    smitty99 likes this.
  16. May 25, 2017 at 9:39 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Here's a good list to start with https://www.tacomaworld.com/threads/3rd-gen-tacoma-areas-of-concern-listed.470778/
