another off road lights wiring question
Discussion in 'Lighting' started by fidencio74, Jul 25, 2010.
  1. Jul 25, 2010 at 8:19 AM
    fidencio74
    fidencio74 [OP] Well-Known Member
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    I just finished my Hella 500 HID conversion and I got a touch switch from Autozone, The switch has an LED light that stays on all the time and I would like it to be on when the ignotion is on. Can any one tell me where to get the power from? I have a relay the goes direct to the battery and the power from the switch that goes straight to the battery also. Which fuse can I tap it to? or may be the light does not draw enough current to drain the battery.
    Thanks for the help.
    Problem solved. I went off the cigarrette lighter.
  2. Jul 25, 2010 at 8:23 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I'm no light pro but having it always on from the battery just doesn't seem like a good idea to me. I'm sure some on else will tell u what wire u need to splice into if you want to have it on when the ignition is on
  3. Jul 26, 2010 at 7:03 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I see in your update you solved the problem. The cig lighter works, or tap a fuse labeled something like "ignition" or "12V accessory" or "12V switched"...that's the 12V typically connected to the ignition.
    Check out my electrical basics/reference page for more info (link in signature)
  4. Jul 27, 2010 at 8:23 PM
    fidencio74
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    Thanks for the info.
  5. Jul 27, 2010 at 8:39 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    in your fuse box next to your battery, tap into the green wire that comes in at the top...it should be bundled with 4-5 other wires.
