Another oil leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Dec 12, 2019.
  1. Dec 12, 2019 at 4:37 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    For the past few months when I park on my concrete driveway I noticed an oil spot. 18 months ago I had OEM valve cover gaskets replaced. This past spring/summer I replaced the oil pan (OEM) and OEM crank seals and OEM cams seals....what the hell could this leak be from??? Getting it looked at today
    GQ7227 likes this.
  2. Dec 12, 2019 at 5:28 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i sure hope its not the rear main seal!
  3. Dec 12, 2019 at 5:35 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    He already said that I the first post but I guess hopefully it's not that again
  4. Dec 12, 2019 at 5:43 AM
    vettehigh
    Jon
    Upstate, NY
    The leak is coming from the front it seems by the way I park. Hope it is not the rear main. If so, what should I do?
    GQ7227[QUOTED] likes this.
  5. Dec 12, 2019 at 5:44 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Check your oil cooler, looks like a tuna can on the driver's side of the engine
    GQ7227 likes this.
  6. Dec 12, 2019 at 5:45 AM
    vettehigh
    Jon
    Upstate, NY
    It coming more from the passengers side it seems. If I look dead center at the front of my truck, the leak is more on the passenger side
  7. Dec 12, 2019 at 5:47 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    if it is do not freak out!
    breathe slowly and stay calm
    but sounds like it is probably not being its on the side
  8. Dec 12, 2019 at 5:50 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i thought he said 'crank seals and cams seals'
    the rear main is totally different??
  9. Dec 12, 2019 at 5:50 AM
    Speedytech7
    Rear main is the rear crank seal
  10. Dec 12, 2019 at 5:55 AM
    vettehigh
    Jon
    Upstate, NY
  11. Dec 12, 2019 at 6:06 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    to replace that RMS does the auto transmission have to be dropped?
  12. Dec 12, 2019 at 6:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
  13. Dec 12, 2019 at 6:10 AM
    Speedytech7
    Yeah on Toyotas it's a one piece seal, transmission or engine must be removed for access
  14. Dec 12, 2019 at 4:23 PM
    vettehigh
    Jon
    Upstate, NY
    The valve covers are bone dry.....the rear main is dry....the oil pan is dry....no leak from the oil filter or drain plug....
    I did spray the underneath with Corrosion X HD 2 months ago, wonder if when things heat up it drips?
    GQ7227 likes this.
  15. Dec 12, 2019 at 4:23 PM
    Speedytech7
    That could be. How do the differential tube seals look
  16. Dec 12, 2019 at 4:26 PM
    vettehigh
    Jon
    Upstate, NY
    Thought of that after I left, but with my bottom covered with Corrosion X it would be tough to see.
    What are the tube seals?
    GQ7227 likes this.
  17. Dec 12, 2019 at 4:34 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    A spot??!? Are you kidding me? Mine leaks so bad nothing under there is ever gonna rust... :anonymous:
    GQ7227 likes this.
  18. Dec 12, 2019 at 4:51 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Front diff? Power steering? Time to look at other things that could leak.
  19. Dec 12, 2019 at 4:53 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    When I got my truck, I noticed the passenger side of the engine/crossmember/frame etc had considerably less rust than the drivers. Found out why during my first oil change. The mess caused by the 3rz filter seems to have kept that area well protected from rust haha.
    Rachelsdaddy[QUOTED] likes this.
  20. Dec 12, 2019 at 6:17 PM
    vettehigh
    Jon
    Upstate, NY
    Power steering is dry...I'll check front diff. Besides the drain/fill plugs, were else on the diffs can leak? Thanks
