Another Oil Q-Tip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Oct 19, 2021.
  1. Oct 19, 2021 at 2:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    Alright, your persuasive rationale has now convinced me. Where do I sign up?
    Junkhead, Skydvrr and sdsurfer like this.
  2. Oct 19, 2021 at 2:48 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
  3. Oct 19, 2021 at 2:51 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Hey listen... more power to you if you actually do this. I like to take care of my stuff too. But if I didn't know any better I would think today was Friday and you were just looking to start a new dumpster fire... :bananadead:
  4. Oct 19, 2021 at 2:52 PM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    No. I’m not instigating- sorry.
  5. Oct 19, 2021 at 2:54 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Gotcha... no need to apologize. I hand it to you for your diligence.
  6. Oct 19, 2021 at 2:56 PM
    ReefSR54X4
    ReefSR54X4 JerzeeBwah
    Jersey
    2016 BB AC SR5
    i definitely appreciate your passion for clean oil, and it is expensive.. I must say during the first 5-20k miles on a new engine it’s important to change due to possible metal shards from factory…
    But filtering it yourself is a bit odd
    & time consuming. Most ppl don’t have that and will pay for new. Keep on keepin on I’d say :notsure:
    :thumbsup::oldglory:
    by the way- I had a Dakota 02
    From day 1, changed the oil and filter every 3k miles. It has over 275k on it and still on the road. Valvaline 10/40
  7. Oct 19, 2021 at 3:01 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Cold start: something something o_O
    Ok so the oil film does not completely disappear, not like you hit the engine with brake cleaner and reassembled it. Yes it will start with a weak fluid film, but the component loading is also low (relative to design spec). If you give it at least a few seconds to a minute before hammering on the gas, it’s fine.
    Remote start only runs 15 min, depending on ambient it likely will not hit operating temp. That sucks for oil life way more than sitting since it has to consume the additive package faster and circulates the water moisture, which doesn’t get warm enough to vent off.
    Just change it every 5k or year if you are paranoid. Not like Toyota completely half assed the engine engineering.
  8. Oct 19, 2021 at 3:01 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    That’s nothing. I remove contaminants from my oil after each drive by draining it and transferring it into a homemade centrifuge that’s powered by my stationary bike. I work off a thousand calories and whirl those contaminants out.
    Then I fill a doll shaped like Scarlett Johansson with the oil to keep it warm until morning via spooning. I wake up early enough to fully disassemble the motor so I can hand lubricate every component, then reassemble, then poor the remaining oil in directly from
    Scarlett.
    Obviously this works because the engine hasn’t seized even once yet.
    Barsoom, Anton338, Kremtok and 7 others like this.
  9. Oct 19, 2021 at 3:07 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    First off.... Okay!!!...
    Second, oil has additives that makes the oil cling to metal parts to prevent dry oil start up. As @tonered mentioned, if you have ever taken an engine apart even after draining the oil, all the parts are covered in oil. Even wiping them down the oil still clings to the parts. So starting your truck with your remote start only burns fuel.
    Now the other issue with remote starting your vehicle is the amount of idling the engine will be doing. This will wear out your engine far quicker than cold starts. Cold starts are only bad if that's all you do, cold start, barely get the engine warm shut off, repeat. Engines are designed to run... off idle for thousands of kilometers/miles. Some, well in to the half a million... idling engines don't have the same long life.
    Lastly, your overly complicated routine could be doing more harm than good. You are opening up the system way too often and greatly increasing the risk of more contamination than you are trying to clean out. The oil filter system is well designed and proven if well maintained... not over maintained. Following the factory recommended intervals are more than proven to be enough.
    Why do I feel like this a troll!!
  10. Oct 19, 2021 at 3:09 PM
    06trdtaco
    06trdtaco shouldn't be trusted
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    Solid regimen...but all of that work is negated by the fact that you are using that Amsoil garbage.
    Anton338 and sdsurfer like this.
  11. Oct 19, 2021 at 3:10 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    It’s an excellent way to get out of the house
  12. Oct 19, 2021 at 3:11 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    This is wild.
  13. Oct 19, 2021 at 3:11 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Why leave me hanging? Provide the help please.
  14. Oct 19, 2021 at 3:12 PM
    06trdtaco
    Brian
    Cincinnati, OH
    Castrol Edge...this is the way
    mquibble[OP] likes this.
  15. Oct 19, 2021 at 3:12 PM
    #35
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    I don't use Amsoil but you may be at risk of pissing off a few loyalists... :cool:
  16. Oct 19, 2021 at 3:14 PM
    #36
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Haha... that's good stuff but so are others like Mobil1, etc.
    06trdtaco[QUOTED] likes this.
  17. Oct 19, 2021 at 3:15 PM
    #37
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    I have nothing to add to this thread. But I am curious if OP is/was an engineer. My gut says yes.
    piratepegleg, Anton338 and Junkhead like this.
  18. Oct 19, 2021 at 3:15 PM
    #38
    mquibble
    Michael
    2021 TacomaTRD Pro
    cryptolyme and Skydvrr like this.
  19. Oct 19, 2021 at 3:16 PM
    #39
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    FIFY
  20. Oct 19, 2021 at 3:16 PM
    #40
    mquibble
    Michael
    2021 TacomaTRD Pro
    Correctamundo.
